How to Troubleshoot a Nordic Track C2500
X
Jolie Johnson
Based in Austin, Texas, Jolie Johnson has been in the fitness industry for over 12 years and has been writing fitness-related articles since 2008 for various websites. She received her Bachelor of Arts in English and philosophy from the University of Illinois.
By Jolie Johnson, eHow Contributor
updated April 15, 2011
Related Searches:
The NordicTrack is a treadmill designed for in-home use. It offers a speed range of 0 to 10 mph and an incline range of 0 to 10 percent. It folds up vertically to save space when you aren't working out and can be rolled to a different room. The console has 16 preset workout programs and features iFit interactive technology. If you have problems with the console or walking belt, you can often fix them yourself with some basic troubleshooting steps
Instructions
Power Turns Off When You're Using the Treadmill
- 1
Check the reset switch on the bottom of the treadmill near the power cord. If it has tripped, the top of the switch will protrude. Wait 5 minutes then press the switch.
- 2
Check that the power cord is plugged in completely. If it is plugged in, unplug it, wait 5 minutes then plug it back in.
- 3
Remove the magnetic key from the console then reinsert it.
The Console Won't Turn Off
- 1
Insert the magnetic key into the console. Your C2500 is stuck in demo mode if the console won't turn off after you remove the magnetic key from the console.
- 2
Hold the "Stop" button down for a few seconds.
- 3
Press the "Speed" down (-) button. Remove the magnetic key.
The Incline Does Not Change Correctly
- 1
Press and hold the "Stop" and the "Speed" up (+) button. While holding the buttons, insert the key into the console, then release the buttons.
- 2
Press either the "Incline" up or down arrow button. Wait while the incline raises and lowers. This recalibrates the incline system.
- 3
Remove the key from the console.
Walking Belt Slows
- 1
Unplug your C2500 and remove the key from the console.
- 2
Turn both rear adjustment bolts, located on the back of the walking deck, to the left, a 1/4 turn.
- 3
Lift the edge of the walking belt in the middle of the deck. You should be able to lift it 2 to 3 inches off the walking platform. If the belt is still too tight, loosen the bolts another 1/4 turn each.
- 4
Plug the treadmill in and reinsert the console key. Walk on the belt at a slow speed to see if it still slows. Repeat Step 2 if necessary.
c2270
