Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Kodak printer i have a kodak esp 310 and when i put the cd in it says error 101-707 but i then check the code and apparently it is a windows problem any help?
  • Marvin
    Marvin Oct 12, 2011
    Got me, contact Kodak product support..
Martin Murray
    President:
  • 1,623 Answers
Try downloading the drivers from the net and install them , then see if the error is repeated, if it isnt repeated , then as rulds2008 has said it may be a scratched disk
http://support.en.kodak.co.uk/app/answers/detail/a_id/28075/session/L3RpbWUvMTMxODQ2Nzg3Mi9zaWQvckQ4OVdwR2s%3D%2Fselected%2Ftrue/selected/true
Posted on Oct 13, 2011
Brian Sullivan
  • Kodak Master
  • 27,725 Answers
Click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will ((see errors in red)) you will no what exactly what the error was and at what time it occured you might be able to work your way through the problem if its a software issue you might uninstall the program or driver then restart your computer then reinstall some of these files/software
Try going to this site and downloading the driver from here
http://support.en.kodak.com/app/answers/detail/a_id/36460/selected/true
Also this is a link to the Firmware that installs on your printer too
http://support.en.kodak.com/app/answers/detail/a_id/17438/selected/true
hope this helps
Posted on Oct 12, 2011
Grand Canyon Tech
  • 3,866 Answers
Scratched disk!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
My kodak printer esp 3.2 is giving me an error code 3533 paper jam but there is no paper jammed and when i put new paper in it, it still wont print and keeps giving me the same error code 3533
Turn off the printer and unplug it. Open the top access panel. Inside on the left you will see three round, white gears. Rotate the gear closest to the front back and forth with your finger. If any scraps of paper appear near the rollers, remove them. Close the top access panel. Plug in and start the printer. This worked for a Kodak ESP 3.2.
Kodak Printer ESP 3 Error Code 101-707 when installing driver
Try downloading/installing and/or upgrading the .net from microsoft first.
KODAK ESP 3200 SERIES WILL NOT SCAN
I had the same problems; missing Icon and 100-2105.
This solution on the Kodak web site solved my problem.
http://support.en.kodak.com/app/answers/detail/a_id/1276/kw/ERROR:%20100-2105/selected/true
From your computer desktop, select Start > Run.
Type %windir%, then click OK.
Double-click the twain_32 folder.
Right-click the kodak folder, then select Delete.
Insert the KODAK All-in-One Printer Software CD into the CD drive, then go to D: > printer > scanner.
NOTE: The CD is indicated by D: above. The CD drive may be a different letter on your computer.
Double-click aioscannr.msi, then follow the instructions to remove it.
Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
Start Home Center Software.
Select Scan Documents and Pictures.
Scan a document.
If the error continues using a Wi-Fi connection, make sure you select the correct printer in Home Center Software.
If the error continues using a USB connection, see the following section to reinstall the printer.
3helpful
I just bought A Kodak esp 3250 series AIO printer. I can print from computer, copy and all that but whenever I try to scan to computer or even preview scan I get a error saying :An error occurred while...
Try a new USB cable. Scanners require bidirectional communication with the computer and thus can fail when printer itself works. (If you use a print server or USB hub, try a direct connection.) Also try changing USB ports.
Another thing to try is to remove the TWAIN driver and reinstall it. This requires the original software CD from Kodak.
1. From your computer desktop, click Start > Run. (In Windows 7, type run in the search box then click on Run.)
2. Type %windir%, then click OK.
3. Double-click twain_32.
4. Right-click Kodak, then select Delete.
5. Insert the KODAK All-in-One Printer Software CD into the appropriate drive, then go to D: > printer > scanner.
6. Double-click aioscannr.msi, then follow the instructions to remove it.
7. Go to D: > printer > scanner, then double-click aioscannr.msi, and follow the instructions to install the file.
8. Open Home Center Software:
a. Select Scan Documents and Pictures.
b. Scan a document.
Unfortunately, if the error persists, the scanner may need service. Contact Kodak: http://www.kodak.com/go/contact .
I hope this helps.
Will not let me install new printer ESP-5 CD
Kodak printer ESP-5 CD version 3.2 is not compatible with Vista. You will need to upgrade to Firmware 4.3 Windows XP/Vista from Kodak Printers. The drivers may be found here:
http://www.opendrivers.com/freedownload/280436/kodak-esp-5-all-in-one-printer-firmware-4.3-windows-xp-vista-download.html
Hi i have a kodak ESP 5 printer and having a problem with it. the printer and computer display printer error 3802 after i print my first picture, could you please help me with this. many thanks keiron
try and reseat the print head twice........to check how to take out and put in print head you may visit www.kodak.com/go/printheadsupport . If you still get that same error then its for print head failure and just need to contact Kodak.........
1helpful
2answers
Kodak ESP 5 software error "UI file missing"
Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center software and click on PRINT pictures. Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals.
2helpful
I keep getting error 1-2070
Resolution
Check to see if the required files are present:
  • Go to C:\WINDOWS\system32\kodak. Check for 2 folders "kds_aio5000(for AiO 5000 series printers) and kds_aioesp(for ESP series)
  • Depending on printer model, open kds_aio5000 or kds_aioesp.
    • For kds_espaio it should only have the lib folder. It doesn't have the ekaiowia.dll
  • Inside the lib folder it should have cct.ekpgct, hippo.dll. Both for kds_aio5000 and kds_aioesp.
  • If hippo.dll is missing then try the following:
Option 1: 1. Go to C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup\printer\scanner 2. Right click on aioscnnr.msi and choose uninstall once this is finished reinstall it by double clicking on the same msi file. 3. Check to see if the scanner files are now present (see above) if not then go to Option 2 Option 2: 1. Insert the Home AiO CD. Go to CD rom drive\printer\scanner 2. Right click on aioscnnr.msi and choose uninstall once this is finished reinstall it by double clicking on the same msi file. 3. Check to see if the scanner files are now present (see above) if not then go to Option 3 Option 3: (manual installation) 1. Go to C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup\printer\scanner or on CDROM drive ..\printer\scanner 2. Open the aioscnnr.cab file then look for the missing file(files needed: cct.ekpgct, hippo.dll, and ekaiowia.dll) Extract the files anywhere on to the computer (Desktop is preferable). 3. Copy the cct.ekpgct, and hippo.dll to C:\WINDOWS\system32\kodak\kds_aio5000\lib 4. Copy the ekaiowia.dll to C:\WINDOWS\system32\kodak\kds_aio5000
Code errors on kodak easyshare esp 3
error code 3501 means the front access door is open on the printer. Error code 3502 means the paper tray is empty. The error code 3602 means the print job did not finish printing.
for more hrlp visit CBR Tech Solutions
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
David Shaub
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
