The F1 error code means that a button on the touchpad is stuck and sometimes it could be resolved by clearing the code by pushing the cancel button, having done that and it no longer clears that F1 code the touchpad would need to be replaced to keeping it from beeping nonstop.
The part number for that touchpad is 82063B it could be picked up at your local appliance parts store or online at;
searspartsdirect.com
apwagner.com
apdepot.com
repairclinic.com
GENE
Hi
Error
code F1 means that an error with the keypad has occurred. Usually it happens
due to loose ribbon cable on the keypad or the electronic control assembly
itself going bad. To resolve this issue first, disconnect the power to unit and
then gain access to the back of the clock assembly (Electronic Range
Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would
be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable
is not broken and nothing is shorted on the keypad. After this is done insert
the cable back and then plug the unit back to check. If the error is still
there then the electronic control board should be replaced. Hope
this helps...please post back for further assistance.
Daniel
