SOURCE: ice and water dispenser not working but light on constantly
CM, there are 2 things that'd cause this. One is inexpensive, the other is not. First, check the cheap one... That rectangular rubber piece in back of your dispenser area is only a cover for a cantilever device. When you push in on this with a cup, the cantilever swivels back toward you and makes contact with a micro-switch. This switch sends power to the integrated circuit board which, in turn, performs the function you requested (cubed, crushed, water). OK... unplug your fridge. Then use your ears to diagnose this. Push the actuator pad several times in and out and listen for the tell-tale "click click" of the micro-switch. If you hear it clicking, it's good. Plug your fridge back in. Now for the expensive part. If your micro-switch clicks, your dispenser control board is fried and needs to be replaced. (I'm afraid that this is the case because the board controls the light as well as all the other functions.) UNPLUG YOUR FRIDGE BEFORE REPAIRING! To gain access the board, use a small flat blade screwdriver and remove the fascia panel starting at the bottom first. Just begin prying it gently off. Then remove the screws that are holding the board assy in place and gently pull it out. Take note of all of the wiring so you can re-install it correctly. The board number you need is #61005274. Unfortunately, it lists for about $100. A professional repairman would charge you over $200 for the repair, so you're actually saving money here! BTW, we recommend using a Belkin Surge protector for all appliances that utilize electronic controls. (you wouldn't plug you computer directly into a wall outlet, would you?) We regularly use these... http://www.acehardwareoutlet.com/(a1q3xi45sxgfbzm0qejhei55)/ProductDetails.aspx?SKU=3115672
SOURCE: Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
SOURCE: ICE BUILD UP ON THE BOTTOM OF MY FREEZER BELOW THE LAST TRAY
clear ice and with hot water pour into the drain hole till open and drains ,, take back panel of freezer out and wrap a piece of thick cooper wire around the heater and drop into the drain hold about 1in and it will keep drain open / thanks
SOURCE: Ice and water dispenser stopped working
Welcome to the computer world. When depressed, the paddle actuates a switch attached to the bracket above. The switch sends a low voltage signal to a small circuit board mouted right behind the display. A computer chip on that small board communicates with another chip on the main control board mounted in the rear wall. Your situation could be a bad actuator switch, a broken paddle tab, possibly a bad door switch (the fresh food doors must be closed to dispense), or a bad electronic control.
SOURCE: I have a maytag MSD2754GR, the freezer bottom is all iced
The drian hole has become stopped up and ice has accumulated in the the drian hole. You will need to unplug the fridge and remove the cover on the back (located at the bottom, 6 screws). On the freezer side there is a drian hole with a rubber 90 and a clear line that runs to the drain pan. Remove line and unstop. Don't not put the line back on yet.
Now for the fun part, remove the basket and the two bottom shelves from the freezer. Half way up the back there are 2 screws that need to be removed. After removing screws pull up on the top cover to so you can remove the bottom cover. The bottom cover maybe froze to the coils and to the inside drain pan. Break the ice with a butter knife, and remove cover ( do not hit the coils). Now you need to break the ice that is froze to the the pan and under it. Once you have remove all the ice you will see the drain hole, use a small pointed object to break ice that is in drain hole. Now you can put the drain line back on and make sure that the other end is in the drain pan under the fridge. Now reassemble the fridge and plug it back up.
It took me about 20 minutes to do this.
Hope this helps.
