SOURCE: need to set timing for tvs victor GL.
http://www.manualz.info/ you can try here for a manual to help you
hope this helped
SOURCE: yamaha yz80 wont kickstart
There is a "C" clip with a stem at a right angle as a part of the clip. This is a part of the kick starter mechanics. Replace the clip. It is about one inch in diameter.
SOURCE: yamaha yz 426 2002 set timing with crankshaft with
The spark will fire at top dead center and you can see it with a timing light or in the dark with the spark plug removed from the cylinder head but still connected to the coil wire and grounded against the motor (don't hold the plug or you will feel a shock, hold it by the rubber insulator.
SOURCE: how do i set cam position and timing on an old yamaha xt 500
You didn't say WHY the cam / valve timing needs to be reset. For some reason I get the feeling someone told you that resetting was needed and so you are asking how. Obviously, you may have installed new pistons and that is why the resetting is needed. In either event, when the cam timing is set the valve timing is also set. Other than adjusting valve lash, setting the cam sets the valve timing. Below is a web site where you can do a free download of a factory service manual. The process is not hard but having a manual will be more help and faster help than I can give online.
http://www.carlsalter.com/motorcycle-manuals.asp
Testimonial: "Thanks for your reply. I've been to the web site before and downloaded the manual already. It does not really cover the situation I have. There also seems to be a lack of compression with the bike. A friend has lent me a workshop manual so I will try that in the mean time. Thanks again "
SOURCE: yamaha yz80 2 stroke or a4 stroke
2001 Yamaha YZ80 Specifications
Engine
Engine Type
2-stroke
Displacement
83 cc
Bore x Stroke
47 mm x 47 mm
Compression Ratio
8.2:1
Engine Cooling
Liquid
Carburetion
Carburetor
26mm Mikuni
Transmission
Transmission
6 - speed
Chassis
Wheelbase
49.5 in
Ground Clearance
13.7 in
Seat Height
33.6 in
Fuel Tank Capacity
1.3 gallons
Forks
Forks
33mm Kayaba
Fork Travel
10.8 in
Shock
Shock(s)
Kayaba
Shock Travel
11.1 in
Wheels and Tires
Front Wheel
17 in
Rear Wheel
14 in
Brakes
disk/disk
Other Information
Intended Use
Motocross
Color Scheme
Blue
Cost when new
$3199
