Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
3" black bars top and bottom of screen. Can't
3" black bars top and bottom of screen. Can't remove.
Posted by Wayne B Kent on
mark
    New Friend:
Either you have the video setting of the television set to wide screen or you are purchasing "WIDE SCREEN" format dvds instead of "FULL SCREEN" format dvds
Posted on Oct 12, 2011
Tip
How do I delete a MySpace profile navigation bar
<p>MySpace has a navigation bar at the top of each page. The links make it easy to navigate to different areas, such as your home, your e-mail, music or even to leave. If you choose to remove the navigation bar and you have the original MySpace - known as "MySpace 1.0" - or even the next release, "MySpace 2.0," code you can create a cascading style sheet in your profile. CSS code sends the web page or hides page elements as shown. However, the latest version of MySpace, "MySpace 3.0," you cannot edit the CSS code. <br /> <p><br /> <p>MySpace Instructions 1.0 <br /> <p>1. Go to MySpace. Log into your account, click the blue "Login" link in the left corner of the site. Enter your e-mail and password in the box that appears, as shown, click the box "Login". You're on your MySpace homepage. <br /> <p><br /> <p>2. Place the cursor on the word "Profile" at the top of your homepage. Finding the "Edit Profile" from the menu that drops under the cursor. Click here to enter your profile in edit mode. <br /> <p><br /> <p>3. Click the Edit link next to a part - no matter what you choose. Select "About Me", for example, and a box appears, allowing you to enter your code. <br /> <p><br /> <p>4. Right-click to copy the following code: <br /> <p>&lt;style type="text/css"&gt; div.profileWidth {margin-top:-30px! important;} div.profileWidth div {filter: alpha (opacity = 0); opacity: 0.0001;} div.profileWidth div.clearfix, div.profileWidth div {filter: none; opacity: 0.9999;} div. clearfix div.profileWidth {position: relative; top: 30px;} div.profileWidth ul li {display: none;} &lt;/ style&gt; <br /> <p><br /> <p>5. Use the right mouse button on the mouse to click in the edit box you opened. Select "Paste" that appears on your cursor. The CSS code that you copied to the section you are editing. <br /> <p><br /> <p>6. Go to the bottom of the page and click "Save Changes". Your navigation bar will no longer appear on top of your MySpace profile - although the navigation bar appears on other pages. <br /> <p><br /> <p>MySpace Instructions 2.0 <br /> <p>1. Go to MySpace and log into your account, click the "Login" blue in the left corner of the site. Enter your e-mail and password in the box that appears, as shown, click the box "Login". You're on your MySpace homepage. <br /> <p><br /> <p>2. Move the mouse cursor over the "Profile" link at the top of the homepage in the navigation bar. Click the "Customize Profile" that appears. The box "Profile 2.0 - Edit Profile" results. <br /> <p><br /> <p>3. Click View in the first column of the box; select "CSS" in the second column. A text box for the CSS code will appear. <br /> <p><br /> <p>4. Right-click to copy the following code: <br /> <p>. MSc {hide the top navigation bar new} <br /> <p>gbltopnav # div {display: none;} <br /> <p><br /> <p>5. Paste the code using the mouse to right-click the text box and select Paste. The CSS code that you copied to the CSS box. <br /> <p><br /> <p>6. Click the "Publish" button at the bottom of the box. The navigation bar will disappear from your profile, even if the other MySpace pages. <br />
on Jun 26, 2011 | Computers & Internet
TruTech T2000D Picture Settings
Somewhere in that menu (look carefully and scroll all the way down on each page) is a setting for format---set should have 4x3 (letterbox), 16x9 which is full screen for HD and may also have zoom and wide zoom.
There should also be a button on the remote for this.
Mar 20, 2012 | TruTech T2000D TV
I have a IBM T210 flatscreen, 20.8 inch. I have done everything possible with the resolution inside windows. I have also gone through every setting in the menu's of the monitor. The monitor is working...
Can u change the screen from 16:9 ratio to 4:3 or regular if it's available in the menu? Black bar at top and bottom generally signifies widescreen...16:9
Feb 03, 2018 | IBM T210 (Pearl White) Monitor
How can I get full screen with my toshiba 40"" HDTV
Hello
To remove the black bars from the top and bottom, press the [FORMAT] or [ASPECT] button on the remote. The option available to remove the horizontal bars is Zoom.
OK.
Apr 23, 2011 | Toshiba 40RV525R 40 in. HDTV
KDL-32S3000 Problem. We broke remote, so got a new one coming. However, The screen will be normal for 15 seconds or so and then a black bar will appear at top. On the left top of the black bar it will...
its asking you to adjust power on the main power box it sould be under power saver adjust level it to low it should be in your menue and then your main power setings.
Feb 06, 2011 | Sony Televison & Video
Black bar down middle of screen
these cables are machine installed on the panel itself, not user fixable. however, the cables are mounted to a circuit board at bottom of the screen. to reach they you need to remove nearly all the support structure and boards at the bottom of the panel. there are a number of sensitive parts under there and they have black 'licourus' on the chips to dissipate heat. good luck.
May 05, 2009 | LG 42PG20 42 in. Plasma HDTV
Hd channels black bars
I am sorry but no one can help with that, it is because the original itself is in that ratio. But if u have a zoom option in ur remote then u can remove that black bars.
Thankyou
Feb 02, 2008 | Panasonic Consumer CASSETTE WALKMAN...
Black bars in the picture
For Models: CC4352, CC4362, CC4393. Your camcorder has a wide format recording mode that lets you make recordings compatible with the 16x9 format. When 16x9 is activated, the camcorder records black bars at the top and bottom of the picture to produce the wide-screen (movie) effect. This is also known as "letterbox" recording. Do not use this mode unless you have a compatible 16x9 TV. When played on a regular TV, black bars appear on the screen. If the 16x9 feature is activated on your camcorder and you want to turn it off, press REC/PAUSE to pause recording, and repeatedly press DIGITAL EFFECTS until no digital effects display appears.
Sep 06, 2005 | RCA CC-432 Camcorder
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
