SOURCE: MALBER WD 800
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
SOURCE: MALBER WD 800 WASHING MACHINE USER MANUAL
Sorry, I don't know what your question/problem is. If you need a manual, I have one for WD 1000, but not for WD 800.
SOURCE: Malber WD 1000 dryer help...
jack it should start turning after a while as soon as the dryer has warmed up.
Does it dry however?
SOURCE: Malber WD 1000 takes four plus hours to dry one load
i would check the thermostat and heating element. one or the other is not on enouph to dry your clothes.
SOURCE: I have a Malber WD 1000 and need to replace leaking drain hose.
The malberusa website has a phone number for New York. Try there. I think the office is in Garden City, LI
Good luck.
