Question about Indesit W 123 Front Load Washer
Indesit wixe167 won't start no doorlock light showing door lock was coming on during a wash cycle and stopping the machine were able to restart but now there is no door light coming on thus unable to start the machine.
Posted by Mick on
sheakhly
    New Friend:
  • 32 Answers
You need to change the door switch by a new one
Posted on Oct 12, 2011
I have indesit washing machine which has door locked and won't go through any of the cycles. Please help. X
Your doorlock is defective. And needs replacing... common issue with these locks
Kind Regards
Indesit Hotpoint Technician
Jun 09, 2015 | Indesit Washing Machines
Whirlpool WFC7500VW1 won't start
My Whirlpool washer model WFC7500VW1 will not start--the green Start button keeps blinking and the red Door Locked button keeps blinking. I do not get any error codes.
Feb 23, 2013 | Whirlpool duet Washing Machines
Indesit washing machine IWC6165 will not start a wash cycle.
my Indesit washing machine start washing normally taking water and spinning and draining but for each cycle i have to do manual its automatic cycle is not working by it self the way it meant and suppose to be . for example if i start on number 3 to wash it just stay on number 3 not moving to next cycle . plz can anyone knows why this happen .?
Dec 23, 2012 | Indesit Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Indesit washing machine not working - took back panel off and there is a big black stain on the inside. Has the motor blown?
if the black that you refer to is like a fine powder all over the inside of the washer it is likely to be the brushes in the motor that have failed
when you remove them they should be at least 20mm long
new brushes available cheap online
Nov 16, 2017 | Indesit Washing Machines
My washer panel will light up and the load washer light will come on, but the machine won't start
To me that sounds like the problem may be within the door switch/lock, on the doorlock asm. is a little botton that sticks out of it,look and see if its their or perhaps its broken off. What that button does is tells the washer the door is closed so it can go ahead and lock it to start the cycle,its perhaps broken off sothe machine doesnt think the door is closed and thusly wont start.
GENE
Oct 06, 2011 | Kenmore Elite 45986 Front Load Washer
INDESIT WI101
hiya
these machines will do this if the timer dial has been moved during a cycle, they have a memory chip on the main circuit board.
they also do this if the machine has a fault with the exception that they dont stop, the doorlock light flashes and the timer just keeps clicking.
try setting the timer to a dot on the settings then switching the power on, the doorlock light will flash a few times, turn off again select program then switch back on, machine should now be reset and work ok, if not then count the flashes of the doorlock light as this indicates a fault code.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Indesit W 123 Front Load Washer
Door won't lock and washer won't start
means your doorlock is either not alligned any more or you need a new door lock. Not overly easy to put in but it can be done.
Door latch can be obtained here and drawing is HERE
Jun 16, 2008 | GE WSXH208A Front Load Washer
Indesit W 123 Front Load Washer Logo
1,054 people viewed this question
Top Indesit Washing Machines Experts
peter gittos
peter gittos
Marvin
Marvin
Onofrio Taverna
Onofrio Taverna
Level 1 Expert
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
