SOURCE: Brother 5240 laser printer changed toner still wont work.
When a brand new toner is inserted it has a switch that is activated when new cart is installed. Machine has two toner light errors blinking is toner low, full on is toner out all stop, I guess yours has not reconised new cart, was it new out of a sealed box? If so then it failed to reset upon install You can pull apart reset lever on left front of cartridge and reset to original position if you want to get just a little tecnical One sctew carefull gears fall off ,white lever needs to be fully to rear of slot to emulate new cart status.. If brand new cart return to supplier as faulty. If you just refilled it, go buy a real one to prolong life of your product
SOURCE: Brother Hl 5240 printer- toner light on
1) Turn off printer
2)Turn back on
3) Remove Drum and Toner.
4)Press Go for 1 second(it appears to do nothing)
5)Put Drum and Toner back in.
6)Press Go for 1 second(it appears to do nothing)
7)Close door.
Try that
SOURCE: My Brother HL 5240 has
The drum light will flash on my brother HL-5240 Laser Printer when printing but it continues to print just fine. Does this mean the drum needs to be replaced?
SOURCE: Brother Laser HL-5240 has a status light and toner
that error usually indicates that the toner has reached its end of life
or the drum is not properly installed.
i had one person who put the toner in but threw the drum cartridge away.
SOURCE: Brother HL-5240 all lights are on
i got hp officejet j4580 all in one and on the screen its saying to trouble shoot but dont know how
I had a stucked paper inside , i removed it then i had this problem
