Question about SanDisk 2GB microSD Memory Card
Remove write protection of my memory card - SanDisk 2GB microSD Memory Card
Posted by Randi Cowell on
Yang Wang
    New Friend:
Deleted documents or pictures on Mac? iBacksoft'>http://www.ibacksoft.com will help you to get all your lost data back. It can recover deleted pictures, videos, music and office documents in an easy way.
Posted on Jun 28, 2013
  • Yang Wang Jun 28, 2013
    Deleted documents or pictures on Mac? iBacksoft'http://www.ibacksoft.com will help you to get all your lost data back. It can recover deleted pictures, videos, music and office documents in an easy way.
    Deleted documents or pictures on Mac? iBacksoft'>iBacksoft Recover Data for Mac will help you to get all your lost data back. It can recover deleted pictures, videos, music and office documents in an easy way.
ridoykhan
    New Friend:
I have a my memory no four met of tha sho unable to fourmet write proteket
Posted on Apr 27, 2013
Ayat Nile
    New Friend:
Posted on Dec 04, 2015
Mafatoo Allen
    New Friend:
If you lost any data on your Memory card you can try iDisksoft Data Recovery, it can recover all your lost data back.
Posted on Jan 14, 2013
ishadi aplus
  • 149 Answers
Micro SD write protect means there is damage to the firmware. Micro SD write protect, the data can be saved. Follow these steps:
Step One:
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process repair micro SD.
Based on experience, the following methods can be used to repair the damage: RAW file system, used space 0 bytes, free space 0 bytes, micro SD can not be in the format, micro SD corrupt. To write protect a micro SD cases, 40% probability of success. But, you can try it. Good luck.
Step Two:
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, the first way
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extract.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Posted on Oct 12, 2011
nirenxizhi
    New Friend:
Windows password reset software can help you bypass your Windows login passwords. It is a safe way for resetting passwords; you won't lose any data with it. You may download Windows password reset software from: http://www.passwordreset.biz
Posted on Feb 15, 2013
1 Related Answer
Anonymous
  • 45 Answers
SOURCE: how to remove write protection on a memory card
Removing the write protection depends on the source of the problem.
Broadly speaking, it can be any of the following scenarios
  1. There is a write-protection tab on the mini sd card HOLDER. Every time you insert this into your PC or card holder, this tab slides to the write protect position. Either keep resetting, inserting & reinserting until it doesn't slide or tape it down.
  2. There is nothing wrong with the mini sd card. Simply locate the write protection key and push it.
  3. The mini sd card has some error: Go for a low level formatting.
  4. The card has virus: Remove the virus. The link for the steps is present in the related link at the bottom of the article.
There is an easy way to solve this problem: Simply put the yellow lock in the middle of its slider. No sticky tape required, as shown below. But if your still having the same problem i suggest you try the sticky tape.
problem is only that small moveable yellow lock switch is not making, just put sellotape over it maybe two layers needed to make switch.
== Answer == Even though what is written below may work, the problem is probably that on the card reader (if you have one) there is a small switch that has lock written on the side. If this is pushed down, the drive is write protected, push it in the opposite direction and it may fix your problem I had the same problem with several cards but eventually found a way around it. DON'T buy a new one!
Make sure the SD card lock is 'off' and then use thin, opaque sticky tape (ie non see-through; eg insulation tape) to cover the whole gap but keep clear of the metal contacts at the back.
Your card should work fine now... don't know why this has to be done, but it works! Additional info:
Reason #1,
the mechanical lock switch accidentally moves to the "locked" position during insertion due to the poor quality of the switch. Hence, by taping it, you are actually preventing the lock switch to travel towards the lock position. i.e. downwards.
Posted on Jul 09, 2010
Tip
How to remove write protection of memory card
To remove write protection
In your memory card adapter have a switch to on/off write protection.
pull this switch to down ,you can remove write protection of your memory card
thank you
on Dec 19, 2010 | Cell Phones
Plz help me to remove write protection from my micro sd card.
Hi, slide up the Write protection switch which is white in color for the Memory Card Adapter to remove Write protection and Slide down to enable write protection of the Memory Card.
Please click on the link below to view the Write protection switch:
http://kb.sandisk.com/euf/assets/images/faqs/id1102_e3sdhc.gif
If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
Apr 16, 2011 | SanDisk 2GB microSD Memory Card
When i try to add music in to my card adapter pny SD 2 gb it says it has write protection and to take it off what do i do?..
thank you
Dec 23, 2010 | PNY 2GB microSD Memory Card
hai friend
thank you
Dec 19, 2010 | SanDisk 2GB microSD Memory Card
I would like to remove write protection. Is this possible? Thank you for your assistance in advance. George Van Etten
thank you
Dec 18, 2010 | SanDisk 4GB microSDHC Memory Card
How do i remove the protected card from my camera
When this problem occur you need to set the memory card unlock or not protected. Remove the memory card from camera and you can see a small button in the memory card, so you need to slide that to set the memory card unlock or not protected.
Jul 27, 2010 | Fuji FinePix A201 Digital Camera
How can i remove the write protect in my memory card if it doesnt have a slidable lock
The procedure for removing the right protection is given in the website given below.
please follow the directions and you can remove it.
http://www.troublefixers.com/remove-write-protection-on-usb-pen-drive-or-memory-card-or-ipod/
Thanx
Jul 20, 2010 | SanDisk 2GB microSD Memory Card
Memory card protected
If your memory card is protected, remove the memory card. Look at your memory card you can see there a small push button push it so that the card will not protected. Reinsert your memory card to your camera.
Regards
PCmania
Sep 28, 2009 | Kodak EasyShare C653 Digital Camera
To remove write protection of my memory card for nokia 6630
we have dissame phone model... and i think i can help you ... get the memory card and a card reader and connect it to a computer then format .....in the computer you can format it
Jul 24, 2009 | Nokia 3230
SanDisk 2GB microSD Memory Card Logo
2,779 people viewed this question
Top SanDisk Electronics - Others Experts
Marvin
Marvin
ChinthakaJ
ChinthakaJ
Ekse
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
