SOURCE: I need to reset the lamp hours on an Hitachi CP X380 projector
hold rown reset on panel for about 3 seconds, wait for display, press reset again and select 0.
SOURCE: HItach cp-s860 problem
I have the same Hitachi CP-S860 and have found the problem is with the convergence on the left and right sides of the picture. The one I am working on has a bad ghosting problem also - you can really see the ghosting when the MENU is on the screen. The center convergence is OK. Following Pics show Circle / Cross pattern - 1st pic the red, green and blue are turned on - 2nd pic shows green and blue on only. I do not have the service manual for this set so I do not know the convergence procedure on this one. I have mostly been repairing NEC, Sanyo, Panasonic and Christie LCD & DLP Projectors.
SOURCE: Instruction Manual
Pls try here. You would need Adobe Acrobat Reader to open, view and print this type if file.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
