Plantronics (45647-04) for S10, T10, T20 Consumer Headset Logo
Anonymous Posted on Oct 10, 2011
Instructions for set up of... plantronics s10 head set and mic to a dsl box and also to use a magic jack.....I only have one phone line and am trying to figure out how this os done???any help would be very appreciated... Carrie
Anonymous
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 537 Answers
  • Posted on Dec 19, 2011
Anonymous
Expert
Level 2:
Prodigy:
Answers
537
Questions
0
Helped
161579
Points
569
The S10 amplifier/headset system sets up like the Plantronics S12 system of which the user guide is included in the link below. As you will notice, it is designed to work with a telephone. It will not work as a stand-alone unit. To connect it to a dsl box, magic jack or any other line you will need a phone.
Plantronics S12 User's Guide
Good luck from Headsets Direct!
Why does a CS6124 not work with Magic Jack?
that phone should work with magicjack , you are not getting a dial tone because you are no setting it up right somewhere along the line ,
Magicjack doesn't always work right sometimes the phone works , sometimes I get an error 3002 message when I try to call out.
Actiontech what, they many vast models, and routers, and mix.
what are you exact connections here>
NO PC stated, HP model number, this is HP forum. so.....what?
no OS stated, opr. system , windows WHAT?
No modem models stated.
No ISP service stated,
what ISP, what service,? DSL> must I GUESS that?
My guess is not DSL no land line but it is possible to buy DSL
with Landline, disabled, I did for years.
or cable modem, ? uses COAX ! not 2wire twisted like DSL.
or are you doing the MAGIC jack , with NO COMPUTER owned
yes?
The magic jack does not plugin to any modem ethernet port
ever. its usb.
t
Broadband, high-speed internet, cable internet, DSL - WiFi, Fios fiber. and more , dial up? nah you dont have LAND LINE./
error codes,. the first page in the manual states !
Contact your Internet service provider to verify your modem allows more than one device to access the Internet if you receive error 3002 when trying to use MagicJack Plus. Some modems and modem/routers-in-one may not be compatible for use with MagicJack Plus if multiple devices are connected to your network.
We dont know what ISP you have nor the connection type
cable tv modem, DSL, FIOS what?
nor the modem you have , you never said,
this is far more complex
its not magic at all,
fire walls set wrong
ISP blocks you, at your mixed, router and modem
using the routers, USB port is a FAIL.
if you want great help answer what you have and what is connected
in details.
the MAGIC jack as 3 ways to connect,
USB or ethernet.?
High pitched sound when attempting to use the headseat rather than the handset. I have tried all of the settings on the side of the desk moduel.
It sounds like it may be plugged into the wrong jack on the phone base. The cord from the S10 HAS TO BE plugged into the jack where the curly cord from your phone was plugged in. You can't use the headset jack, this will cause the high pitch sound you are hearing.
Telephone line RJ11 jack does not fit into plantronics
The correct connection size for headsets used with S10, T10 & T20 is an RJ9. The jack on the back of the T10 and T20 is an RJ9, this is for the cord that runs into the wall jack. The cord itself has an RJ9 on the end that plugs into the T10 & T20 and an RJ11 connection on the other end that plugs into the wall jack. This cord is supplied with the units.
5helpful
3answers
Calls cutting out with magic jack
Your ISP connection speed may be inadequate. Typically, the upload speed (outgoing voice) is much slower than the incoming speed. To check majicjack recommends that you test your system on http://www.speakeasy.net/speedtest/ .
It's also possible that your internet provider is purposely delaying the outgoing latency in order to discourage VoIP that THEY don't provide. I think this is (or at least should be illegal) but in any case a complaint to the FCC might be in order.
Plantronics 510s wireless headset
that head set you have bourght, has a different pins for a mouth piece. (mic)
open the equipment and the three wires if its sterio, tip, ring and sleeve. sleeve is ground for both a mic and ear piece.
or check the ear piece wires with the jack connected to the set. use contnuiety resistance.
Connection of Canon Multipass C3500 to Juno DSL phone line.
Read the instructions again again...u probably got it set up wrong..
Plantronics headset S10
First, try a headset that you know works.
Ethernet cords
The cord that plugs into the DSL filter is a phone line and the other end plugs into your DSL modem. Also, every other jack that has a phone or fax or answering machine or caller id box has a DSL filter as well, in between the jack and the device.
Top Plantronics Radio Communications Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
