Roper RAS8445KQ Top Load Washer Logo
Question about Roper RAS8445KQ Top Load Washer
Roper washing machine is not agitating. Makes a horrendous noise when supposed to be aggitating. No noise when filling with water.
Anonymous
  • 2,341 Answers
In addation to the agitation does it make the same noise in spin??
If yes it makes that same noise in spin the problem is going to be a broken motor coupler. I have written this tip about a broken motor coupler it will show ya how to take apart the washer and replace the coupler. http://www1.fixya.com/support/r10293994-whirlpool_made_washer_not_agatating
GENE
Posted on Oct 10, 2011
Roper washer model RAS8245EQ1 not working, buzzing noise
Her you'll find your answer..
http://www.appliancerepair.net/washing-machines-forward.html
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
2answers
Not spinning or rinsing?
After the machine fills the next step is to agitate. By agitate I mean the wash portion. The plastic fin in the middle of the tub rotates back and forth. So, after the washer fills, if the machine does not agitate, but stops dead, you have a broken lid switch. When I say stops dead, I mean no noise whatsoever. If the machine makes noise you have other problems.
If the machine fills, agitates, and then stops dead, the problem is still the lid switch. The next step would be describing the noise so I can more accurately give a suggestion. Problems include but are not limited to: broken couplers, malfunctioning water pumps, and/or defective motors or transmissions. These are the vast majority of the problems, and the others need no mention.
With a model number I can give a part number of the lid switch, and or other problematic parts. Also, I can give you an average price of the parts. With this information you could order it yourself and save money :) The model numbers are located under the lid of the washer. Not physically on the lid, but right under it. Get eye level with the top of the washer and you will see it ;)
Roper washer RAX4232PQO doesn't agitate or spin
It sounds like you may have a broken motor coupling. This is a common problem that usually occurs through normal wear and tear. Replacement couplers are more resilient and resist breaking much better. If the washer will fill, will not agitate or spin, but will still drain, these are the symptoms of a broken motor coupling. The accompanying noise of the motor engaging and a rattling/grinding sound is also a common symptom. This is a very simple and inexpensive repair. The following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The part number is included in the link I provided. You can purchase a replacement on line at appliancepartspros.com for about $11.
If you have any questions, please let me know. I hope this helps you.
NOTE: Roper is manufactured by Whirlpool and uses Whirlpool parts, so these instructions will apply.
Agitator stopped moving back and forth
Hi, Can you tell me if the spin cycle works? It sounds like maybe a couler has gone bad. Also check and see if the lower half of the agitator is working at all.
Please let me know and I can help you through this.
Thanks
Vic
Noisy aggitation
You have a 2 piece agitator and it is worn out. You can either replace the entire agitator or get a repair kit for it. Hope this helps!
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
2answers
Wont agitate
My washing machine fills up fine, but then when its time to start aggitating and spin's it makes like a metal on plastic grinding noise, We would like to try to fix it ourself but have no idea which part it is. Could you please HELP?
dismantle the agitator and see if the shaft of the gearbox is moving.its either the gearbox or the agitator
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Thomas Rutkowski
Thomas Rutkowski
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
