If the fault is only with the DISPLAY then there is no need to be concerned as this is due to low filament voltage or grid volage or a faulty display driver IC.
So check with the filament voltage which is about less than 3 Volt AC. Also check for the display grid negative to the IC and display so as to confirm the case.
If there is no other issue you might as well not tamper if you are not equipped as a false move can cause heavy damage.
