Hello [1] Manually turn on the component [2] Locate the enclosed Code Lists. Find the list for the component you wish to program. Find your component's brand. You will see a listing of four-digit codes for each brand. If your brand isn't listed, use one of the Code Search methods to [3] Press and hold the component key (TV, VCR•DVD, SAT•CBL) you wishto program. The illuminated ON•OFF key turns on and remains on. If you release the component key at any time during the Direct Code Entry procedure, the illuminated ON•OFF key blinks four times, [4] While holding down the component key, consult the Code Lists for the four-digit code that corresponds to your component's brand and use the number keys (0-9) on the keypad to enter it. While you are pressing the numbers, the illuminated [5] After the fourth number is entered, the illuminated ON•OFF key turns on. At this time, release the component key. If the illuminated ON•OFF key turns off, you have entered a valid code and have followed the correct If you enter a code number that is not in the Code Lists or you do not follow all of the steps for Direct Code Entry, the illuminated ON•OFF key blinks four times when the component key is released. This is an indication that a programming error has occurred. In that case, repeat the Direct Code
I hereby send tou the general proceedings to synchronise a RCA remote to TVs:
you want the remote to control.
program the remote control.
and the process is exited.
ON•OFF key turns off.
procedure for Direct Code Entry
Entry process from step 3.
These are the proceedings with RCA RCR-311 remote control. Most of the RCA remotes will have this process itelsf. OK.
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
SOURCE: need codes for rca universal remote rcr312w. for apex tv
With your model number at hand, check the RCA website for a later code list.
If you are the exception, you might find one.
Most all remotes have a 'search' function that lets you scan through all of the available code sets but this feature will, in most cases, provide only minimal functionality such as Power, Volume and Channel.
In truth, there isn't any such thing as a 'universal' remote, including the 'learning' remotes; I have one of those and it is unable to 'learn' from either of my later sets' remotes.
At best, these should be called (honestly) 'multi-brand.'
SOURCE: program the RCA#rcr312 universal remote control
hold the code search buttton until light comes on then select the device you are programing and enter code
