Question about Lexmark X2600 InkJet Printer
What's C 5 E blinking in the printer screen? - Lexmark X2600 InkJet Printer
  • Official Brand Answer
  • 3,344 Answers
The EC5 error code indicates that there is a short in one of your print cartridges. Please follow the steps below to identify and fix the issue:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Should the problem persists, please contact Lexmark Technical Support Center for additional assistance.
Posted on Oct 12, 2011
What does it mean when you're printers exclamation mark is blinking
Many things.Maybe there is toner/ink cartridge problem, paper jam, electrical problem and many more. If you tell us what is the model of your printer and is this blinking is repeating .
Jul 13, 2012 | HP Office Equipment & Supplies
When printer is turn on that time printer reddy and cartridge light on so what is the problem
You can see four LED's on control panel, from top to bottom,1st is toner indication 2nd Attention 3rd is Ready light, 4th go light.. Observe led's are 'blinking' or 'On' condition.. # If toner light is blinking ="toner cartridge missing or contact problem or memory faulty.
# If toner light & ready lights are on= "toner low indication or refilled cartridge loaded".
Jul 12, 2012 | HP LaserJet P2015dn Printer
After paper jam, printer won't initialize
try to switch it off unplug leave for 15 min and switch back on.
Jun 30, 2012 | HP P2055DN LaserJet Monochrome Printer
Control Panel
Have you made any restore points lately, that might help.
Feb 24, 2012 | HP Computers & Internet
HP F4140 Printer - all lights flashing, blinking E
This is a printer hardware error, you cant try below reset methods.
Power Drain:1. Unplug the printer power cord from wall and the printer, disconnect USB cable from printer.2. Press and hold the power "ON/OFF" button for 30 seconds and release it.3. Connected the power and check the printer.
Dec 08, 2011 | HP DeskJet 6988 Printer
The status light is blinking red. I am assuming that one or more of the toner cartridges is out. How do I get the computer to display the toner level?
You need to visit the samsung website and download the 'smart status monitor' which will give you the toner levels and also tell you what the status of the printer is. Once loaded, it will appear in the bottom right corner of the screen, a right click on it will bring up the monitor and status of the printer.
Sep 11, 2011 | Samsung CLP 300 Laser Printer
Amber light on oki c3300 continues to flash and printer will not print
Here's what the owner's manual has to say:
Error status (Amber, blinking): you cannot continue to use the
printer. Intervention is required to recover from the error. Fatal
errors are irrecoverable and require a service call.
Blinking 1 (2S cycle)
An error has occurred but
printing can continue if you
press the ON LINE or CANCEL
switch.
Blinking 2 (500mS cycle)
An error has occurred. You
need to replace consumables
or remove jammed paper, for
example. The printer then
recovers from the error and
printing becomes possible
again.
Blinking 3 (120mS cycle)
A serious error has occurred.
rebooting or a service call is
required.
The Status Monitor in Windows provides a readable description
of the printer status corresponding to the indications of the
LEDs. In Mac, the printer driver provides status information
once you have sent a document to print. In Windows, if you
have the Status Monitor Preferences set to Pop up on alerts,
this readable message will be presented on screen whenever
an abnormal condition occurs.
There's no further information. Sorry.
Jul 19, 2011 | OKI C3400n Laser Printer
Blinking/flashing lights(orange & green) & won;t pring. Have rebooted computer and unpluged printer. still won't print.
that is because ur head of ur printing cartridge is damaged.
remove ur cartridges black as well as color
n install only black cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur black cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of black cartridge is damaged
after this process remove the black one cartridge and install the color one cartridge n check d blinking of lights on ur printer if it doesn't blinks it's mean ur color cartridge is OK but ur blinking of light on ur printer is same it's mean ur head of color cartridge is damaged
now take a dry cotton cloth n gently clean ur cartridges head install both cartridges on ur printer n check ur blinking light on ur printer that will work only if u r too lucky other wise u have to purchase a one cartridge.
May 29, 2011 | HP DeskJet 5550 InkJet Printer
Lexmark X2600 InkJet Printer Logo
626 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
