Palm Treo 680 Smartphone Logo
Anonymous Posted on Oct 09, 2011
I have a palm treo 680 and it want pick up signal.. how do i fix this?
5 Related Answers
Anonymous
  • 377 Answers
  • Posted on Mar 26, 2008
SOURCE: my palm treo 680 turns itself off repeatedly
hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
quakefiend
Jeffrey Johnson
  • 15 Answers
  • Posted on Jul 19, 2008
SOURCE: USB Device Not Recognized for Palm Treo 680
if you are using Vista ultimate, it is a 64 bit operating system and therefore palm doesn't have official support for it yet, but someone has found a solution:
http://forums.palm.com/palm/board/message?board.id=windows_hotsync&thread.id=17980
A
Anonymous
  • Posted on Jul 23, 2008
SOURCE: use wifi in palm treo 680
WiFi is not supported in the 680. I understand that the Centro and the new 800W have it. (Me, I'll wait for the 800p before I trade in my trusty 680.)
Anonymous
  • Posted on Oct 31, 2008
SOURCE: palm treo 680
Here is a video on youtube that you can see how to open your cellphone.
http://www.youtube.com/watch?v=hlYfI4_P_n4
Anonymous
  • 54 Answers
  • Posted on Jan 03, 2010
SOURCE: why my palm treo 680 always no signal?
Four things it could be are:
1. You are in an area that doesn't provide service for the sim card you have inserted.
2. There is a bad connection inside the phone between the antenna and the main board.
3. If it is locked for a network and a different network's sim card is inserted it may cause this problem.
4. A problem with the main board or the firmware could be the culprit.
Unfortunately, unless you have experience with these phones it will be difficult to diagnose which is your problem.
What is the code to unlock palm treo 680
To Unlock the Palm Tero 680 Model You can get the Unlock code at here
http://www.superunlockcodes.com/palm-one-treo-680/rs12wp9/ and Unlock it...
1helpful
Why my palm treo 680 always no signal?
How do i deactivate airplane mode for palm treo 680
This can be easily remedied by holding the red button on the right. The phone will say "Hello" at the bottom of the screen and find a signal.
This is also the procedure activating "airplane mode."
How do I change the language to my palm treo 610
Remove the battery and Insert then change the language settings.
best luck.
Tmoible sim to a palm treo 680
all you have to do is get the unlock code. I bought one from a cell phone company over the internet for $20 put it in my phone and ive been using t-mobile for 6 months with no problems!
2answers
Use wifi in palm treo 680
Need owners manual for palm treo 680
Here is the Manual
http://www.palm.com/us/support/handbooks/treo/treo680gsm_GSG.pdf
Here is an AT&T Owner's Manual for Palm Treo 680
http://palmone.r3h.net/downloads.palmone.com/documentation/treo680att_UG.pdf
3answers
Palm treo 680
i need to know how to block private incoming calls on my palm treo 680
Top Palm Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
