Sharp R-303CW Convection / Microwave Oven Logo
Question about Sharp R-303CW Convection / Microwave Oven
I need a manual for sharp model r-303cw
  • Sharp Master
  • 6,609 Answers
I haven't found the instruction manual available as a free download online. However, there are several places to buy a copy. Sears Parts Direct has a printed copy for sale for $4.49 here: http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R303CW/0958/0123245/50022360/00001?blt=06&prst=&shdMod= . The current part number is IB-R303CK. Searching for the part number gave several other sites with the manual available.
The Sharp R-308K is a very similar microwave and that manual is available as a free download. See http://www.managemylife.com/mmh/owner_manuals/7167/SHARP-Countertop-Microwave-L0906397?brand_name_search=Sharp+microwave .
I hope this helps.
Posted on Oct 09, 2011
  • 1 more comment
  • Anonymous Oct 09, 2011
    Cindy replied to my question very quickly. It was
    Cindy replied to my question very quickly. My problem has been solved. Thank you so much.
  • Cindy Wells Oct 09, 2011
    You're welcome.
How to fix Sharp Carousel Microwave Oven R-303CW clock not working?
The clock is part of the control board and cannot be repaired as a separate item. Most replacement control boards costs as much as
a new microwave.
I need a sharp microwace maual
You can find many of them online here.
Otherwise, you would have to order yours.
You can order Sharp parts and manuals from Encompass here or you can call them toll-free at 866-779-5835.
SHARP MODEL R895(SL)M TURNTABLE NOT TURNING
Check turn table motor operating voltage on the motor if the voltage is normal then check motor pulley(crack or broken) ,if o.k replace motor with the same type,if the voltage is missing go to the control panel and find out any wiring problem,if everything o.k replace control panel.
2answers
User Manual Needed for Sharp Carousel Microwave Model R-303CW
mcdevito75 here, Best Bet, contact Sharp online, try sharp microwave oven.com Or in any store that sells Sharp microwave ovens get contact info off that package.
Need replace tray for turntable R-303cw sharp
Cheapest here:
http://shop.ebay.com/?_from=R40&_trksid=p3984.m38.l1313&_nkw=NTNT-A079WRE0&_sacat=See-All-Categories
Eric
2helpful
The display no longer works on my Model R303CW Sharp Microwave. Is there a part that will fix the display?? Everything else works fine.
Nope , could be dry joints or corroded pcb or defective display driver or supply ? Only can be told once opened and inspected.
1helpful
Don't know how to use defrost
defrost, than number 1-5 (should just use 5) then amount of pounds like 3.0, 4.0, 5.0
2answers
Need glass replacement, what is part number or size
Glass tray or door glass? You should be able to get either part via Tritronics at http://www.wehaveparts.com
Top Sharp Microwave Ovens Experts
Jaime Hernandez
nu267
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
