Logitech Harmony 550 Remote Control Logo
Anonymous Posted on Oct 09, 2011
Harmony 550 not recognizing the USB port Currently my Harmony 550 shows in safe mode and when I try to update the firmware, it says to plug in the USB cable and/or press a button to wake up the remote. Help?
5 Related Answers
HyeProfile
HyeProfile
  • 35 Answers
  • Posted on Aug 05, 2009
SOURCE: My harmony 550 remote is in Safe Mode and will not
Did you try this response from the Logitech users' forum? It can't hurt to try since all your settings are stored on the web, not on the remote.
http://logitech-en-amr.custhelp.com/...i=&p_topview=1
Basically, Safe Mode is a diagnostic tool in the Remote used for troubleshooting purposes. If the words "Safe Mode" or "Safe Mode Requested" appear on the remote, complete the following steps:
1. Ensure the Remote is in "Safe Mode Requested" by taking out the batteries, and disconnecting the remote from the USB cable.
2. Hold down the Off button and plug the remote into the USB.
3. Continue holding down the Off button for another 10 seconds. The remote should then display the words "Safe Mode Requested".
4. With the unit in "Safe Mode Requested", re-install the firmware by clicking Support on your home page.
5. Click Firmware in the Downloads section and follow the online instructions to upgrade the firmware.
6. Once the firmware upgrade is complete, click Update My Remote.
7. Insert new batteries into the remote.
Anonymous
  • 86 Answers
  • Posted on Aug 29, 2009
SOURCE: harmony 550 in safe mode
Hi There,
To get out of safe mode, do a firmware update from your PC. This will install the latest firmware and your configuration. Safe mode is a bootstrap designed to recover from firmware corruption issues so about the only thing it knows how to do is reload firmware.
However, if the remote fails to communicate with the PC when it is stuck in Safe Mode, please try the following.
1. Remove the batteries from the remote & check for any stuck buttons especially the Power button that may be causing the remote to stay in this state.
2. If it still will not apply firmware to get out of safe mode, then still without batteries hold down the #2 button while plugging into USB, and it should exit Safe Mode, and say something similar to 'Firmware Upgrade Success'. Even though it says this, still perform the Firmware upgrade since it was stuck in Safe Mode to begin with.
Anonymous
  • 100 Answers
  • Posted on Oct 03, 2009
SOURCE: harmony 550 is locked on safe mode
Try this:
  1. Remove the batteries from your remote
  2. Press and hold down the 2 button while connecting the remote to your computer
  3. The Harmony Remote LCD screen should display Upgrade Success
That should do it. If it doesn't work try pressing all the keys and make sure none are stuck in the down position and then retry the above steps.
Anonymous
  • 89 Answers
  • Posted on Feb 28, 2010
SOURCE: My Harmony 550 remote is stuck in safe mode. What
Hey!
I thought this link might help get your Harmony 550 working again:
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=11941
Hope this helps!!!
-Kennedy
A
Anonymous
  • Posted on Mar 05, 2010
SOURCE: my harmony 550 displays safe mode . how do i fix it?
Hi . Here's how to fix it and get your remote out of safe mode:
1. Connect your remote to the computer.
2. Launch the Harmony Remote Software, and log in.
3. Click "Downloads" at the top and click "Firmware"
4. The remote will go through the firmware update.
5. Select "Yes", and click NEXT to update the remote.
Voila! Hope this can help
Harmony 550 Remote Control: Logitech 525 says safe mode how do i remove...
update the firmware on the remote
- connect the remote to your computer and launch the software - click downloads at the top of the screen - click firmware - update the remote
1helpful
My harmony 550 displays safe mode . how do i fix it?
It blinks safe mode
To solve this problem you need to update the remote firmware.
Load Logitech Harmony Remote (install it from original CD or download it from Logitech) them connect your remote to any USB port and select UPDATE REMOTE option.
The screen disply reads "harmony safe mode", we purchased the remote with our tv @ 1yr ago, but recieved no tech papers or cables to hook to lap top. Thanks Steve
The Harmony 550 uses the same UB chord as most digital cameras. It's a Mini-USB .
Also, you will have to download the Harmony software from http://logitech.com/myharmony.
Now, please do the following to get your remote out of safe mode:
1. In the software, click "Downloads"
2. Click on "Firmware."
3. Update the remote
14helpful
Harmony 550 in safe mode
Hi There,
8helpful
2answers
Remote is in safe mode
You can try this solution to your Harmony 550 Safe mode problem:
Harmony 550 Safe Mode Fix Safe Mode is a diagnostic tool in the Remote used for troubleshooting purposes. If the words "Safe Mode" or "Safe Mode Requested" appear on the remote, complete the following steps:
Hope that helps.
3helpful
2answers
It says safe mode
Hey!
I got my Harmony Remote stuck in safe mode and found the following link that got it working properly!!!
I hope this helps!!!
-Kennedy
7helpful
My harmony 550 remote is in Safe Mode and will not respond to any button I push. How do I get my remote to work again?
Frozen Harmony 550
Hi. You will need to update the firmware.
That should fix it!
2helpful
550 Safe Mode
Hi. Here is how to get your remote out of safe mode.
Voila! Hope this helps.
Top Logitech Televison & Video Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
