Sounds like the main tub bearing is going
Parts for Whirlpool WTW7600XW2 Motor Basket and Tub Parts
SOURCE: loud noise, then not so loud, but now electrical burning smell and little draining
The basket drive and the drive block will need replacing. The nut that holds the basket to the drive block may have come loose causing the drive block to 'jump' over and damage the tabs on the basket drive that causes the thumping as the spin cycle ends. To repair, you will need to purchase a basket drive and drive block. The agitator, balance ring, basket and transmission, will have to be removed in order to replace the basket drive. If less than 3ys old, consider contacting whirlpool for possible warranty concession.
SOURCE: whirlpool washing machine
It sounds like the porcelein on the inner or outer tub is damaged allowing rust to form.
Another possibility is that there are iron deposits in the internal hoses that are loosening.
I would (assuming you can afford the water wastage) run the machine on 'full load' and 'hot' several times with no clothes in it to see if it will flush out.
SOURCE: Found oil and grease under washing machine. Makes loud noise when on spin cycle.
The oil and grease is probably from the transmission and yes you might be able to replace it. Get your make andmodel number and go to www.repairclinic.com. It is a very good site for finding pictures and parts of appliances. The parts are as cheap as you will find them. If the oil/grease is from the transmission, it will eventually fail. Fix it now or fix it later. Your choice.
SOURCE: There is not enough water in the machine
sounds like the pressure chamber is blocked or the pressure switch is faulty
SOURCE: greasy oil and water is leaking from under the washing machine?
Hello, the good news is the water is coming from the pump and is easily replaced, the bad news is if you are seeing a yellow oily substance your transmission has a leak and will go bad at some stage soon. The question here you need to ask yourself is do you want to spend $35 on a new pump when your going to need to buy a new washer? If so pull the machine out and puch it back so it leans against the wall umder it's own weight. wedge some thing underneath the washer so you can access the bottom without the washer falling on you. you will see the pump attached to the motor which is attached to the transmission. remove the 2 clips and 2 pipes from the pump, remove the pump and replace it, reassemble in reverse order, you should be able to see where the leak came from the pump at the point where the motor shaft connected to the pump. Also while you are under there look at the base of the transmission, you should see some oily residue where the transmission fluid is leaking. Hope this helps! if you have any other questions please feel free to comment again. Good Luck!! Mike
