Question about Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack
My 18 volt Ryobi battery shows charged in charger (Green Light) But will not work in any of the power tools. I have three other Batteries that do work. Bought at Home depot on july 24 2011 Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack
Posted by Tom Pollock on
  • Simon Woodward
    Simon Woodward Feb 02, 2019
    Tom, I'm having this problem too? Did you ever get a fix?
  • Anthonu Gerrard
    Anthonu Gerrard Feb 24, 2019
    has any body got the solution to this
wwlvictoria
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,001 Answers
  • USB quick charge 2.0 charger,you can get 75% power from empty in 30 minutes. It also charges your non-QC2.0 devices at up to 2.4 amps.ideal for travel use.
Chornic Quick Charger 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
Posted on Dec 07, 2016
bbmbattery
    New Friend:
Some of batteries drain very quickly. Depends on how they are used.
Feel free to check Your Local battery Manufacturer for best prices for all different batteries. You name it and they have it or they can custom make a battery for you.
Thanks
Posted on Aug 15, 2012
5 Related Answers
HomePlicity
Jeff Bonvallet
  • 41 Answers
SOURCE: Does it harm a Ryobi 18v lithium battery to leave on Charger?
Lithium-Ion batteries require careful charging and temperature monitoring while in the charger. Ryobi's Charging station monitors many functions and shuts off when the battery has gone through a complete charge. This is indicated by a steady Green light. Once the Charge indicator is a steady green the charger stops charging. With any battery It will slowly discharge and I don’t think the Ryobi will maintain a battery that is never removed. For example, if after a complete charge cycle if the battery was left there for 2 years and then you went to use it, it would likely be completely discharged. However if the battery charger is unplugged then plugged back in a new charge sequence would start. I lose power at my house about every 6 months or so. Once power is restored a new cycle would start and the charging cycle begins again.
Hope this helps and have a great day.
Posted on Apr 01, 2010
Testimonial: "This is the best answer I received! Thanks!"
Anonymous
  • 15 Answers
SOURCE: Compatability issues with new Ryobi Lithium Ion Batteries
something is wrong. take it back if possible.
Posted on Oct 10, 2009
Anonymous
  • 8 Answers
SOURCE: New Ryobi 18v lithium battery goes dead after a
No, just return it, for the money they should give you one that works. It is common to get a defective Ryobi 18v lithium battery. I've had 2 out of 7 purchased that wouldn't hold a charge. But when you get a good one they work awesome!
Testimonial: "The answer was very helpful. Thanks!"
joboo1
Jim London
  • 257 Answers
SOURCE: Ryobi 18V lithium battery won't charge
Hi, Thanks for getting back to me. The yellow and blinking red indicate a defective cell. Since it has lithium cells and is that new any repair to it would be a waste of your time. Ryobi tools purchased in 2008 have a 2 year warranty. I am guessing you probably got it at a home depot and you should return it under the warranty. All new Ryobi tools have a three year warranty. Good Luck! and Thanks for using fixya!
Posted on Feb 05, 2009
Anonymous
SOURCE: how do you take apart a ryobi lithium 18v one
This applies to Li-ion. NiCd is probably somewhat different.
Unscrew four security screws on the bottom of the battery. If you don't have the right bit you can grind down the center pins in the screw heads and use a T15 bit.
Unscrew the hex-head screw in the center of the protruding post at the top of the battery. It may be non-standard in size but a small metric hex key wrench works if you are gentle. The four corners of the battery cover should be loose now.
There are still two plastic clips holding the top cover to the main unit near the centers of the long dimensions. Gently push a knife blade into the crack between bottom and top to release the clip on each side.
As you lift the top cover off you should push down on the contacts near the top of the post so you don't pull on the attaching wires. Eventually the contacts should pop free and the top cover detaches.
Detach the wiring harness for the status LED from the circuit board. You can now remove the combined circuit board and battery pack from the lower case.
Six screws attach the circuit board to the battery assembly, along with several solder connections, but you probably don't need to go this far. You can now test and possibly replace individual cells.
Posted on Nov 16, 2010
Ryobi charger bcl1418
Usually this is indicative of a bad battery. First try a good battery in the tool to make sure it is OK. If the tool is OK, you need to try charging the good battery in the charger to see if the charger is working properly. If the charger is OK, replace the bad battery. Some batteries will show fully charged on the charger but will not supply the power to the tool.
Oct 08, 2012 | Ryobi Drills
I purchased a brand new P113 Ryobi charger about 2 years ago. It has never worked. If I put a P104 battery in for a charge, it looks like it works correctly. I push the battery tester on the battery...
If you have your receipt, check with Ryobi to see if it is still under warranty. It comes with either a 2 or 3 year warranty, depending on when it was purchased. If it is still covered, get it replaced/repaired. If it is not, buy the P117 charger. $30 at Home Depot. It has a 90 day satisfaction guarantee. If it charges your batteries properly, you're good. If not, bring it back if you don't like/want it. My P113 won't get out of test mode now, or charge Lithium batteries anymore. So I bought the P117 yesterday. Works great, and it's a lot cheaper than new batteries! And it has a 3 year warranty.
Aug 28, 2012 | Ryobi P113 18 Volt One Charger 140501001
Red light in charger flash when battery is put in to charging
This behavior is typical of trying to charge a battery that is wither too hot (let it rest for a hour) or one that has done its job and is ready for the battery retirement home. Replace your battery for best results with your Ryobi battery powered tool.
Jun 02, 2011 | Ryobi Multi-Volt Battery Charger
Ryobi p103 battery charged but dosen't work.
You need to have the charger tested, if you know that batteries are good then what else could it be. This LIon charger has a logic circuit in it like a computer.
May 17, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
Very little juice in freshly charged batteries
have you tried the batterys in any other tool?
you would also need to check the voltage of the batterys they should be at least 18 volts (19 prefered)
then if the batterys do not show charged you would need to make sure the battery charger is putting out voltage.
After that contact your closest Ryobi service center we would check that for free to let you know what you need, I am sure you local place would do the same.
Mar 16, 2009 | Ryobi Drills
Ryobi lithium batteries won't take charge
For others with the same problem (flashing red light won't go off)...make sure you FIRMLY PUSH the battery down onto the charger and engage the latches. Simply resting the battery on the charger will not work.
Jan 30, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Charger not charging
Just was on a website for Ryobi drills and it states that if the yellow and green light stay on for more than 15 minutes the battery is fried. Couldn't find the link but if you do a search for Ryobi Drill 18 volt you should find the same info. It was as product review from Australia I think.
I also have a problem with the charging of Ryobi batterys. They seem to charge AOK with the green light coming on but the charge does not last at all. Not sure if the problem is with the batteries on the charger.
Jan 07, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Ryobi 18 volt batteries wont hold a charge
Ryobi batteries are specific to each Ryobi model, so please write down which model number or the original battery part number you have. How old are the batteries?
I had the same problem with many bateries I had at home, like cell-phone batteries and also some power tool bateries. Did not have any Ryobi power tools tho, so don't hold me acountable if this doesn't apply to your hardware:)
Many batteries have the "memory effect" which means that if the battery was not completely empty when it was set to recharge it might now only recharge to the level it was emptied to, so for instance if you used the power tool for 10 mins and the battery emptied to, lets say, 90% capacity, it might occure that the next time you recharge the battery it will only charge to it's 90% maximum...doing that many times lowers the maximum recharge capacity. As I heard the new Li-Ion batteries do not have this problem.
I hope this makes some sence as my english is not that good and it was a bit hard explaining my thoughts:)
Nov 25, 2008 | Hand Tools
Ryobi Two  18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack Logo
11,208 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Marvin
Marvin
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
