Washing Machines Logo
Anonymous Posted on Oct 09, 2011
How can i do a quick wash - Whirlpool AWG320 Front Load Washer / Dryer
2answers
A128QW BUSH washing machine.When set to number 7 for quick wash when it gets to spin cycle light flashes and nothing happens? do you know what can be done?
If this only happens on quick wash, it could be that this cycle does not spin. I have come across a few washers that do not spin on short or quick wash cycles. If it spins on all other cycles, I would say the machine is OK.
How to do a quick wash
You didnt state what machine you have but if your machine has a quick wash it will have a setting for that cycle every machine i delivered GE Maytag LG etc all had a quick wash setting on the dial if this doesnt help call manufacture to see if your machine has one good luck
Whats the quick wash
The one that says "Quick Wash" next to it
This is my Beko 6kg a class 1200 rpm washing machine. I'm looking for the quickest wash. It has a quick wash button but I can't seem to find a quik wash. Like a 30 minute wash??
The machine washing speed is not only TIME but WEIGHT... If you are able to push the Quick Wash, then that is the Quickest to get the job done "RIGHT"
Not doing quick wash
Possible failure of the controller unit. Check and see if all the other functions are working. If so check the water level control unit as in quick wash the level can be set lower. Also if there is no start on the quick wash program then the program controller needs to be rechecked for output.
Takes ages to get through wash cycle
You should have a quick wash on your unit. By using a concentrated washing powder you can do your washing on quick wash mode which most manufacturers set to approximate 30 minutes. In a front loader most clothes can be washed on a quick cycle. Because of the way they wash.
How do i change the run time on the quick wash
most run times are at factory settings, an cant be changed, the quick wash , is a quick one.
1helpful
Can you please tell me how to do a quick wash on the beko wm5120w washing machine,.
The only washing machine they have a manual listed for on their site is the WM5140.
CLICK HERE
Should be similar to yours.
You can only select QUICK WASH in 6 programs - listed on page 18 of the manual.
Simply select the program desired, and click the Quick Wash Button.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Which programme saves the most energy?
yes a quick wash is for coloured clothes that have been worn once or twice and dont have bad stains on them.This quick wash will take between 30 and 50 mins to do a wash and is the best programme for the clothing that I have discribed ie: worn 1or2 times and no stains will save you on electric and water peter
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
