Question about KitchenAid KUWA244PBS Wine Cooler
I purchased a 52 bottle kitchen aid wine cooler. No matter where I set the thermostat, it is always 45 degrees and readouts are sideways "T's" instead of numbers.
Posted by Del Bohulano on
John Tripp
  • KitchenAid Master
  • 4,656 Answers
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download. I purchased a 52 bottle kitchen aid wine cooler. - arrow_results_summary.gif Get Adobe Acrobat Reader Click Here=> KUWA244PBS Parts List
and here=> KUWA244PBS User and Care Guide
If you should need the service manual you will need to cant me here=> HERE Reason is Whirlpool does not allow me to publish the SM here.
The beverage center and wine cellars have a temperature display for each zone. 12 volts
AC is supplied to the display board from a transformer in the unit compartment. The displays are only temperature displays and have nothing to do with any cooling function. A thermistor is used to sense temperature for each zone. The thermistor for the bottom zone is located inside the lower portion of the separator. The thermistor for the top zone on the wine cellar, (mid zone on beverage
center), is located in the upper portion of the separator. The thermistor for the beverage center upper zone is located on the inside of the 2-piece evaporator cover. It is on the right-hand side.
The mid temperature for the bottom zones on either unit are 60? Fahrenheit plus or minus 5 degrees. The mid temperature for the mid zone on the beverage center and the top zone
on the wine cellar is 45? Fahrenheit plus or minus 5 degrees. The mid temperature for the
top zone on the beverage center is 38? Fahrenheit plus or minus 5 degrees. I think at tis time you should check each section with a pocket size digital thermometer to cofirm tha the mechanical thermostat is within calibration. Click Here=> 4344690 Temperature Control
I purchased a 52 bottle kitchen aid wine cooler. - sea_breeze_250.jpg/images/sea_breeze_250.jpg" alt="sea_breeze_250.jpg" class="h_mi" />
Click here for a=> KUWA244PBS Beverage Center Wiring Diagram
I believe the problem may be in the PCB transformer shown at the bottom right corner of the wiring diagram. It is possible o change the transformer but I have not been able to find the board that powers the LED temperature readouts. If needed let me know and I will call Whirlpool mfor you, Thanks, Sea Breeze
Posted on Oct 09, 2011
Why does my wine cooler run too cold?
If after adjusting your thermostat to desired temp and is still cooling. The thermostat is bad or your relay is bad
If you disconnect the thermostat and the compressor stops it most likely a bad thermostat
If you disconnect the relay from
The thermostat and it stay running it is the relay. It is sticking
If possible store you wine somewhere else and shut the unit down and unplug for 10 to 20 minutes this may cause some melt of condensation some water may be on the floor if is to cold
This may also reset the system.
Jul 26, 2015 | Marvel 61WC Wine Cooler
Manage my life com sears
It depends on if there is anything in it! Those types of coolers are only designed to drop temps of wine bottles to below room temp a few degrees. They don't cool like refrigerator in your kitchen.
Jul 22, 2014 | Vissani MCWC50DST Wine Cooler
I have a Haier BC112G. It is not cooling at all. Temp panel works, so I can set the thermostat up or down, but nothing happens and it just goes back to room temp after that.
Our magic chef wine cooler (mcwc50dbt) when temp is set on digital panel at 45-50 it jumps immediately back to 70 degrees constantly
Sep 25, 2013 | Haier BC112G Wine Cooler
Wine cooler doesn't cool
I recommend that you maybe add more details to your question so it will be easier for Experts to understand the question and answer it.
Oct 06, 2012 | Kalorik WCL-20629 18 Bottle Dual Zone Wine...
I have my Emerson FR966T wine coller set for 60 degrees, but my cooler never seems to get the high. It always hovers around 58-59. When I heat my house up (never above 68) my cooler seems to warm up to...
Yes, because the fridge is a heat exchanger. The trade off for cooling the inside is a condenser coil on the outside which is warm. If you raise the temperature on the outside it will affect the inside a little. Having said that, the thermostat should keep the temperature within specifications. If you have it set for 60 and it is 58 or 59, to me it is within spec.The difference in 2 or 3 degrees Fahrenheit is tiny.
Also it should be pointed out this is a $63 cooler from Walmart. If you want a good one for storing thousand dollar bottles of Chateau Margeaux, you need a $600 wine cooler with a solid state digital thermostat and controls that talks to your smartphone when the temperature is one degree off..
Oct 21, 2017 | Refrigerators
Vinotemp wine cooler temerature won't stay on 54 degrees
If the unit is a thermoelectric unit it can be the cooling system.
If the unit is a compressor unit it will be the thermostat.
Aug 28, 2009 | VinoTemp 32 Bottle Stainless Wine Cooler
I have an Oster 12-bottle wine celler model OWO912H6H that was a Christmas gift in 2007. I just noticed the temperature is 98 degrees and I cannot get it to come down with the down button. I am very...
Hi, could be faulty thermostat, can you check compressor, is compressor running (working), listen to compressor for clicking sound, unplug it(switched off) for about 20 minutes, replug and let it run (work) for another 20 mins. see if temp. drops, what about temp. inside bottle (wine) cooler, is it 98 or colder, more info. could be valuable. check thermostat, check to see if compressor operates, if cooler temp. 98. remove you products, to another cooler, call mechanic.
Aug 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Avanti WC492D wine cooler temperature control does not work
the wine cooler has to be at least 3" away from the wall, do not block the air flow to the condenser. or check power plug to outlet is it secure.
Feb 21, 2009 | Avanti WC492D Wine Cooler
Does anyone know how to lower the temp below 45 degree's.
Dear friend,
ngfam at you service! happy to assist!
No they have no bypass!
How old is this wine cooler! MY ADVICE BUY ONE NEW!
It cost $241 to buy a new one at the site below!
NOT WORTH THE MONEY FOR A COMPRESSOR
Or model #HBCN05EBB FOR $249 96 BOTTLES CAPACITY
http://www.buy.com/prod/bc112g-30-bottle-freestanding-wine-
refrigerator/q/loc/63024/203111423.html
If the dishwasher is 10 years or older its not worth investing money tofix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Jul 07, 2008 | Haier BC112G Wine Cooler
KitchenAid KUWA244PBS Wine Cooler Logo
666 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
Dakshinamurthy...
Marvin
Marvin
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
