SOURCE: kenmore galaxy model 721 microwave hood combination
You put a mounting plate on the wall behind where the unit will be mounted. Then the microwave hooks onto the bottom of the mounting plate and you swing it up to the cabinet above it. Then you must screw 2 mounting screws through the floor of the cabinet above into the bracket on top of the microwave.
SOURCE: whirlpool microwave model #MH1140XMQ-1. I needed
We see (and repair) this
a lot. The problem is on the control panel, which
we regularly repair nationwide by mail for $39.95 postpaid in about a
week or so.
At
our Web site, you can get details of our service, plus we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Or if you prefer, you can order a new control circuit board for it here for $140.10 plus shipping. (Just enter the model number as MH1140XMQ-1 without the dash).
This light failure often
occurs when a bulb goes out and the filament
shorts, or when the bulbs are removed or installed without first
unplugging the oven from the power line. Either can cause such a
failure on the controller.
The lights can can be
inoperable or stuck on or no bright, too. Sometimes this will similarly
affect the exhaust fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more information & help.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: I have an error code
I would like to repair the kenmore mocrowave myself, it has the error code f-9. Do I need to let the micrwave sit for a wile so the hi voltage can disipate from the inverter or magetron
