SOURCE: RCA HDTV Fuse location
There are 3 small rectangles that are on the right side of the flyback, they are micro fuses FL231 is the center one. I am not sure if radio shack has them, may have to order from RCA
SOURCE: RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
SOURCE: RCA 52 in HDTV red, green and blue colors not alligned - concave
That repair only repairs the issue of the convergence option missing from the on screen menu. If thats what your problem is then the ITC222A convergence option missing repair kit at the following link should repair the issue. The kit contains the fl231, DL231, CL230 and the CD with detailed instructions.
http://www.tvrepairworld.com/
SOURCE: i have a 52 inch rca dlp hdtv. the color is out of
Turn off your TV. Hold down the Channel Down and Volume Down buttons on the front of the TV. Hold for 8
seconds. The set will boot into the service menu.
I just fixed my convergence issue with this, no parts.
SOURCE: 52" hdtv rca hd52w67
check that board where you replace the fuse on the back look very close at the transformer the big black one and check the soldering it is cracked resolder it and you should be ready to go.. just look very close they are smalllllll cracks need good light.. thats what i had on mine and works good..
