Water Heaters Logo
JUAN ANTONIO Posted on Oct 08, 2011
ERROR 76 REFERENCES NEGATIVE - Water Heaters
A
Anonymous
tip
Get hot water from your Rheem tankless during a code 76 error
This doesn't always work, but on the Rheem tankless Gas/Propane water heater, if you're experiencing a code 76 error; disconnect the remote control unit (either from the water heater or the remote) by lifting the wires for the remote connection. Typically you'll get a C1-C8 error code, followed by a code 76; if you're getting a straight code 76 and nothing else, this procedure probably won't work.
Code 76 is a total power supply failure on the printed circuit board (PCB) assembly, which is the communication/power supply for the remote control unit. But, if you're getting a supplemental code (C1-C8) this procedure will most likely supply you with hot water until the replacement PCB arrives.
C4 76 error code on richland waterheater
Richland tankless is made by Rheem.
C7-76 is communication fault with remote.
Turn off power at remote and wait 5 minutes, turn power back on at remote, and see if problem clears.
If problem continues, read below:
Before calling service technician, open following links for troubleshoot resources including error codes, Rheem chat, typical maintenance manual:
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Tankless water heater, more than any other type of heater, need to be maintained.
Maintaining tankless will probably not affect C7 76 fault code, but can prevent many other common error codes.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
3helpful
Remote is flashing C8 and 76, alternating. I turn the unit off, then back on, and I get hot water for about 10 seconds, then it goes cold and the same error message occurs. Unit is Rheem Main Remote...
Before calling service technician, open following links for Rheem tankless resources including error codes and Rheem chat.
Disconnect wires from remote to see if system stabilizes. Unit will heat to default temperature without remote.
Error codes are considered start-point for troubleshooting.
C8 76 can mean PC board failure.
76 can mean communication failure with remote control
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
I have a Rheem rtg 74dvp but its not heating and the display show me 1 76 and 2 76, and come all the time to 76 F and another times its blinking the temperature, but not heat
Error code 76 is communication problem between remote control and tankless unit.
Multiple error codes could indicate that main PC board is bad.
Before calling service technician, open following link for troubleshooting resources including link to Rheem chat, manuals, error codes, etc.
1helpful
This past weekend controller showed error codes of C7-76 and C4-76. Cold showers are not fun Iturned off and restarted, unit came on then showed error. [email protected]
I am a free answerer, and I specialize in giving you resources for free
The paid answerers may have a person who knows your product and the error codes
The manual will also have the error codes.
The person who installed the unit will also know the error codes (or should know)
Each day I see 20-25 unanswered questions about tankless water heaters.
The number of questions shows the complexity of the machines, and the inability of the manufactures to take care of their customers.
The manufacturer will refer you to the installer.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
http://www.rheem.com/products/tankless_water_heaters/
The link above goes to Rheem tankless water heaters
Click on a product and it opens a page showing many tankless models
Click 'more information' and another page opens with spec sheets and other pdf
Not surprisingly there are no troubleshooting steps or troubleshooting flowcharts
There are plenty of ways to buy a tankless
There are not many ways a do-it-yourselfer can fix a tankless
3helpful
Noritz f 76 error blinking f 76 and on off light blinking at the same time. Everything works fine turned on and off hot h20 it goes to burner on 120 and then goes back to blinking f 76 after burner...
F76 is a communication error between two quick connected heaters. To clear the code, disconnect power from both heaters, wait 20 seconds, then reconnect power.
3helpful
C4 76
76 is a bad connection between the controller and the unit. try unplugging the controller and running it, also check the wiring between the two units. if that is not it. it means that one of the control boards it shot
Top Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Water Heater Expert? Answer questions, earn points and help others
