An E1 error code is associated with a draining problem. Either it is not draining or not draining in the time specified. Check that the drain hose is not blocked or kinked, thereby stopping or slowing the flow of the water when the machine is draining.Feb. 4, 2020
Error code E3 - Samsung washing machine
When your Samsung Washing Machine shows the error code 3e, the most common reason is because of a "wire harness or wiring connection is loose, not connected, or wiring is damaged".
Error code E3 - Hoover washing machine
Should the error code E3 appears it is warning that the machine is not draining. You can easily fix this problem by removing any blockages from the drain pump situated at the front of the machine for easy access.
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
E74 error
