Question about Hardware & Accessories
I am just looking for a programming manual for my IDEAL 7 day electronic timer
Anonymous
Add a comment and describe the timer buttons for best possible help.
The ideal timer looks similar to GM40E timer module
http://waterheatertimer.org/pdf/gm40e-120-manual.pdf
Posted on Oct 09, 2011
Show how to set the itermatic et821c
Following link has manual for Intermatic ET8100 series
Choose astronomic dawn-dusk timer -or- 7-day programming
http://waterheatertimer.org/Intermatic-ET-series-timers-and-manuals.html#ET8000
be sure to install two AAA batteries in compartment located on front just below the buttons.
Also reset the timer prior to programming ... and this will clear any conflicts or prior programming.
Timer default voltage is 120 volt AC. Choose 208-240-277 volt by moving selector switch located on back of timer.
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
User's guide for kambrook electronic timer kd94
Could not find a free guide, but e-how lists the basic instructions.
Instructions
    • 1 Set the day and time on the timer. Press and hold "Clock." While holding the "Clock" button, press "Day" to scroll through the days of the week and select the correct one. Press the "Hours" and "Min" buttons to select the correct time. Release "Clock" when you are finished.
    • 2 Press "Prog" set the "On" time for the switch. The word "On" and the number "1" will appear on the left side of the display.
    • 3 Press "Day" to choose an individual day or a block of days. Choosing an individual day means that this specific program will only activate on that day; choosing a block of days means that the program will be active on each day in the chosen block.
    • 4 Set the time that you want the timer to switch on by using the "Hours" and "Min" buttons to select the appropriate time. Press "Prog" when you are done to complete your entry of the "On" time.
    • 5 Select the "Off" time for your timer by using the "Day," "Hours" and "Min" buttons to choose when you want the timer to switch off. Press "Prog" again to save this entry. Repeat steps two through six to set additional timers.
    • 6 Press "Day" and "Hours" to activate the random timer mode. An "R" will appear on the LCD screen, indicating that the timer is in Random mode. This will cause your timer to switch on and off at different times, following no set pattern.
    • 7 Press the button that looks like a hand with the index finger extended to perform a manual override. The display will show you whether it is in Manual or Auto mode, and whether it is turned on or off. "Manual On" means that the time is switched permanently on while "Manual Off" indicates that the timer is turned off. "Auto Off" activates the program that you have set, while "Auto On" turns the time on until the next schedule "Off" time, after which it continues to follow your programmed times.
    • 8 Press "Clock" and "Prog" at the same time to use the countdown feature. Use the "Hours" and "Min" buttons to select the length of the countdown, and press "Manual" to start.
    • 9 To reset the entire unit and clear all programmed times, use the end of a paper clip or a ball-point pen to press the "Reset" button, located above the "Manual" button.
Read more : http://www.ehow.com/how_5565934_program-kambrook-timer-switch.html How to Program Kambrook Timer Switch eHow
IDEAL 7 day electronic timer kit 203982 instructions manual
How do I set in Automatic mode, seems to only work manually since loss of power?
1) Power outage is major cause of timer failure. Power surge occurs when power is restored, and electronics are susceptible to surge. This includes water softerer, treadmill, electronic water heater, timers, etc.
Timers should be unplugged when power goes off.
Of all timers on market today, only one instruction manual says to unplug timer with power loss. However many people write fixya saying their timer, and electronic water heater control etc stopped functioning after power loss. Probably other products have same problem, but I work with timers and water heaters and see only that slice of the world.
2) Question posted under Woods 59377.
Several timers look identical or similar.
59377 timer has non-replaceable rechargeable battery, some similar timers have AA battery.
If timer has battery, change battery.
Then reset timer to restore functionality. Press reset button for a few seconds with paper clip.
3) If timer function does not restore after reset, then timer is bad.
Buy similar timer at Lowes or Target, and return defective timer in new package.
4) If function is restored, then re-program timer
Open following link for timer instructions showing how to reset timer and re-program timer:
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
I am an electrician and my client wants me to reprogram the digital timer (Intermatic) I don't know the model # but it looks like the one on the previous page. Probably the most popular digital wall timer...
Below are links to digital timers to help identify your timer.
Manuals for each timer appear on page.
Programming takes patience, which might be why your customer wants you to do it.
And these 1-year warranty timers go bad, and then timer will not reprogram, which may be another reason why customer wants you to do it.
Intermatic EJ500 and ST01C are battery operated, and will not program if battery is low.
Aube has rechargeable battery that is not replaceable, and this timer will not program if battery is bad.
Other timers shown below have clocks that operate on 120V circuit and require white neutral before display lights up.
Generally each programming is same: You set current time. Some timers you set daylight savings time. Some timers are 7-day, and some offer dusk-to-dawn. For 7-day, you set event1 ON and then event1 OFF for up to 7 programs. You choose the days for each event to operate. Before programming, make a schedule so there are no overlaps or conflicts in programming.
With Intermatic EJ500 and ST01C, event1 is the ON event and event2 is the OFF event, up to 40 events.
Add a comment if you hit trouble spot when programming.
Also fixya offers live phone support for a price.
Intermatic EJ500 with 7-day or dusk-to-dawn
Programming remains in memory forever, so you may only have to re-enter current time.
http://waterheatertimer.org/Flipdown.html
Intermatic ST01C with 7-day or dusk-to-dawn
http://waterheatertimer.org/ST01C-program.html
Intermatic EI500 7-day
http://waterheatertimer.org/Programmable.html#EI500
Aube timers are either dusk-to-dawn or 7-day
http://waterheatertimer.org/Aube-timers.html
Utilitec 0192773 with 7-day and astro dusk to dawn
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Utilitec 0141224
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
GE 15071 - 15086 in-wall timers: one has daylight savings time
http://waterheatertimer.org/GE-timers-and-manuals.html
Woods 59018 in-wall
http://waterheatertimer.org/Woods-timers-and-manuals.html
Tork SS720 in wall:
http://waterheatertimer.org/Tork-consumer-timers-and-manuals.html
2helpful
Intermatic Timer HB88RC unable to program it following instructions. Will not turn on in Automatic mode. Works fine in manual On mode.
HB88RC manual online:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb88rc%20-%20english.ashx
These timers are frustrating sometimes, fortunately this timer can be unplugged to set programs under good lighting.
When I have problems, I set it down for a while and then go back to it later.
Right now I own 25-30 different Intermatic, Woods, GE, Utilitec timers for testing and programming difficulties. Each one offers different points that are confusing.
Some new timers are simply defective. One guy today had 2 defective Woods timers, which made me suspect electric line needs line analysis. You might try your timer in another plug, for example indoor plug in another part of house to double check line is not interfering with timer electronics.
Reading HB88RC manual, there is not Dusk-dawn option, and programming steps are pretty straightforward compared with other timers.
This leads me to believe there is some small thing missed or line is bad, or timer is defective.
Return it if it's defective.
Here are some trip-up points, and they may not apply to you.
1) Current day has to be set. Hold clock button down while setting current time.
2) When programming, each event requires ON time and OFF time. For example event1 ON has to be set and then event1 OFF has to be set. Then set event2 ON and then event2 OFF.
3) When programming, check screen carefully to make sure 1ON appears, and then 1OFF appears in screen exactly like Fig1 and Fig3 shows.
Now I frequently e-mail Intermatic asking for manual clarification, and they e-mail back ... sometimes their manuals are a little bit off here and there. But this manual looks clean and matches what I see in other timers.
4) Each ON time requires OFF time for same choice of days. For example ON 7pm Tuesday and OFF 9pm All-days-of-week will not work correctly.
5) ON 7pm Tuesday and OFF 7pm Tuesday will not work.
6) Conflicts in programming cause some timers to skip programming: For example event1 says ON
at 7 pm Tuesday and OFF 9pm Tuesday, but event2 says opposite.
7) Since manual override works correctly, we know Load is functioning, and we know plugs on timer are working. Timer load can be lighting or pumps or heaters, but manual does not specifically say florescent. So timer MIGHT not work for compact florescent bulbs. If you have CFL bulb, try another type of Load: for example incandescent table lamp.
And that's everything I know, like Bubba Gump shrimp.
2helpful
Having Difficulty programing Woods Brand electrical timer !
How to program Woods 59377
Timer has rechargeable battery.
Plug timer into wall to charge battery to see LCD display.
Download Woods manuals
59377 manual
Up to 8 ON/OFF programs per day >> program 1 program 2 ... program 8
Choice of individual days, or blocks of days
Image shows buttons:
Set time of day:
Hold down CLOCK until settings are made
Use DAY button to choose MO - TU etc
HOUR button to set current hour
MIN button to set current minute
Release Clock button and time is set
Program preview
> First I suggest you write out your schedule to avoid conflicts in programming
Manual says:
>For each ON time, you set DAY HOUR and MIN
>For each OFF time, you set DAY HOUR MIN
>Manual shows blocks of days to choose from > for example TH FR SA is one choice; MO WE FR is another choice ,,, 9 possible blocks of days to choose from
Looking at display is critical for programming timer
Look for the number 1 or 2 or 3 etc located on left of display > each program has a number
Look for the word ON that indicates you are setting ON time for program 1 or program 2
Look for word OFF that indicates you are setting OFF time for program 1 or program 2
Program timer
Press PROG once and look at screen ... you will see '1' and 'ON' in tiny letters
Do not hold down PROG button
Press DAY to choose block of day for program 1
Press HOUR to choose ON hour for program 1
Press MIN to choose ON minute for program 1
Press PROG button once to finalize ON time for program 1
Before pressing any more buttons, look at the screen >>> screen shows '1' and 'OFF' in tiny letters
So you are ready to set OFF times for program 1
Press DAY >>look at your written schedule to make sure the correct block of days is chosen >> if you chose ON for TH FRI SAT, do you want OFF on same block of days?
Press Hour
Press MIN
Press PROG to confirm OFF time
Before pressing any button, look at screen and '2' and 'ON' show on screen
Press PROG to advance to program 3 through program 8
Press ON/Off button to exit programming
Other features
Daylight savings time: Press HOUR & MIN simultaneously and clock springs forward 1 hour ... press again and clock falls back 1 hour
Look for S in display to see if timer set for S summertime
Press reset to clear all programming
1helpful
Instruction manual to program HB77R
Here is the instruction manual your looking for:
Intermatic HB77R
Hope this helps and please remember to rate this!
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Tom Chichester
ray gallant
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
