Question about Kenmore Elite HE4 Electric Dryer
Kenmore Elite Gas Dryer: Dryer does not dry clothes completely, even when I set the times for 80-minutes. I usually need to set the timer an additional 60-minutes resulting in 2-hrs + 20-minutes of dryer time for one loan....? Can someone suggest a solution?
    President:
  • 693 Answers
    • 1 Check the dryer's fuse if the dryer's drum operates but does not heat. The fuse may not be working properly if there is a break inside. If it happens to be broken, replace it with a new fuse.
    • 2 The dryer's heating will not function properly if the timer does not work. Fix a bad timer by disconnecting the leads from the motor and setting the Volt-Ohm, or VOM, to RX100. Clip off the probes onto the leads. If the timer is set on infinity, then it needs to be replaced.
    • 3 If the drum is no longer spinning, first check to see if the motor pulley is working correctly. If it is not, then it will need to be replaced. Once everything is dissembled, take time out to clean out the compartment with a vacuum to remove dust and lint.
    • 4 If the dryer still is not functioning, then the dryer's belt may be broken. To fix the dryer's belt, you'll have to replace it with a new one. Line up the replacement belt with markings on the drums seen on the damaged one. Wind it around both the motor pulley and the idler pulley.
    • 5 The roller also could be damaged if the dryer still continues to not work. Fix the damaged roller by removing the tumbler to gain access, then remove the retaining clip on the roller by sliding it off. Reverse the process to install a new one
    • 6 If the dryer is not working at all (when you turn it on by the switch and it still does not work), consider replacing the terminal block. Use the VOM to check for voltage at the terminal block. Use extreme caution as the power needs to be on to run this test. Call an experienced electrician for help if need be.
    • 7 If the dryer is not working still, test to see if the dryer's switches are working properly. Set the VOM to RX1 and get rid of one of the leads to the switch, clipping the probes to the switch's terminals. When the reader is switched to infinity, press the start button. If the reader does not switch to zero, then the switch is bad and needs to be replaced by a professional.
Posted on Oct 07, 2011
  • Mike Oct 07, 2011
    Thank you, Brian for the detailed check list.
    Mike
6ya staff
SOURCE:
Kenmore elite dryer will not work on manual cycles which consist of three options; timed dry, express dry, and touch up. Dryer will work on auto cycles only
most likely the board is bad,the board is big money,just keep using it on auto,that's what you should be using anyway the dryer automatically stops when the clothes are dry,say you set your clothes for 60 minutes and they dry in 40,you're drying the clothes 20 more minutes that you didn't need,if you set it on auto the dryer sensor knows the clothes are dry and shuts it down when they are dry,this doesn't have a timer this has a computer board or it could be the touch pad not working correctly if it doesn't take commands but either part is expensive the board is like 200 and the touch pad is close to 300 bucks,i would use it on auto,one more thing to check is sometimes the ribbon or plug that connects the touch pad to the board could be loose or have some lint or something in it,i've just unplugged them and plugged them back in and then it works,also clean out all the lint out of the dryer and vent line,this is the number one cause of most problems in dryers and you won't have to worry about a dryer fire,if it's gas you should do this once a year yours is electric so you can wait like every 18 months with gas you have a flame in there so you don't want lint in or around the flame,clean out the duct that the lint filter slides down into and i use a leaf blower to blow out the vent line just take it off the dryer stick the leaf blower int the line and blow it to the outside when you have the dryer running go back outside and make sure the air is blowing out good
Feb 05, 2018 | Kenmore Dryers
Timer goes to 99 minutes and clothes note drying all the way
Hi cayjr1
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry.
But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Please take time to rate me
Bud
Oct 09, 2012 | Maytag Neptune MDE5500AY Electric Dryer
MY KENMORE DRYER IS TUMBLEING BUT IT WONT DRY M CLOTHS
Clogged Vent
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Cycling thermostat
This is a free answer, Please rate me
Oct 04, 2010 | Kenmore 73952 Gas Dryer
Model # 11061082000 electric dryer....elite kenmore
you can't get any parts for this dryer the computer board is no longer available,must be old technology replace it.
Dec 28, 2017 | Kenmore Elite HE4 Electric Dryer
Dryer will not turn off
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 20, 2009 | Dryers
Takes too long to dry or keeps running when clothes are dry
May 07, 2009 | Kenmore Elite Oasis 6809 Electric Dryer
We have a Kenmore Elite gas clothes dryer (110.73952101). It will not completely dry large loads. We have to reset timer and restart the dryer. If we set timer for 40 minutes, dryer may run for 10 minutes...
Loads may be too large. Also when you reset and restart, the heat overload is cutting out. If your discarge is kinked or not venting properly this will cause it not to dry as well. Also check your lint screen. Good Luck!
Apr 13, 2009 | Dryers
Dries clothes but runs too long & clothes VERY hot
Fixable and possibly a warranty claim. The timer is bad. You will need to get behind the control panel and remove the timer and replace the timer. First I would call whoever it is that yall bought the dryer through and see how long your warranty is. Most of the warranties are only 1 year. But if you bought a extended warranty then you are covered. The part can be found at repairclinic.com
Feb 17, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore elite model 110.6708 dryer timer problem
Hi thanks for the question. the problem is with a clog in the venting system . remove the vent and clean to the outside. where the lint filter is, use a brush with a long handle, to clean all the way down .do that . this should solve your problem. thanks the appliance doc
Oct 06, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite model 110639101
check for blocked vent tube.You should have a very strong flow coming out.If it is weak it will run badly.It is a common call.If its not weak air flow than run the dryer for at least 20 minutes.Open the door and if has no heat inside .......change the split coils. Please Rate This !!!
Sep 15, 2008 | Kenmore 62602 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
663 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Ned Halaweh
Ned Halaweh
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
