Hello akamacho,
It is possible that you have a "MicroSD card". Most card readers can not read micro sd cards because it is too small, so you will need an "adapter" to be the same size as a normal SD card and then you can use it on card readers. I am just assuming (because I can not see it) that the yellow thing you have is the adapter. Make sure the micro SD card is inserted into the adapter properly and make sure that your adapter is inserted properly into your card reader.
If it is still not working, tell me the brand and model of your computer or you card reader. Also indicate any markings you can read from your sd card and the little yellow thing.
You can rate my answer if you appreciate it.
Thanks!
-damneddle
