Question about Panasonic PT-40LC12 40" Rear Projection HDTV
Panasonic PT-40LC12 I have installed a new lamp unit in a Panasonic PT-40LC12. The lamp unit did NOT come with reset instructions. I am now having trouble setting the lamp hour meter. I have tried pressing the Vol button down and holding down the PIP button on the remote control at the same time for more than 5 seconds. It is not resetting. Please help.
Posted by lropertz on
Ezeldin Fayed
    Habit-Forming:
    New Friend:
  • 54 Answers
Hi...
Panasonic lamp timer reset procedure
1. Press the power button to turn the unit on.
2. There are 3 choices for this step, depending on the housing part number:
A. TY-LA1000, TY-LA1500 or TY-LA2005 While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control at the same time for more than 5 seconds.
B. TY-LA1001 or TY-LA2006 While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
C. TY-LA2004 While pressing the VOL- button on the projection display, hold down the MUTE button on the remote control at the same time for more than 5 seconds.
3A. When the reset procedure is complete the the following screen will appear: LAMP TIME WAS RESET TO 0 (this screen may be different from the actual screen)
OR
3B. The POWER and LAMP LED's on the front of the unit will flash for 5 seconds. (TY-LA2006)
When the lamp time reset is finished, the LAMP indicator goes out. It may be necessary to attempt the procedure several times.
Posted on Oct 29, 2017
4 Related Answers
Anonymous
SOURCE: lamp meter on Panasonic PT-40LC12 ?
I just had my picture go out two weeks ago. I took it to a local tv repair shop. They replaced the thermal fuse. I also had a spare lamp so they also replaced that. I'm not sure if they reset the lamp meter but this is what I found surfing around...try at your own risk. I'm going to try this when I go home tonight.
Good Luck...
While pressing the Vol-(volume down) button on the projection display,
hold down the PIP button on the remote control at the same time for more
than 5 seconds. When the reset procedure is complete the following message
will appear on the screen. "Lamp time was reset to 0".
Posted on May 28, 2008
Anonymous
  • 1077 Answers
SOURCE: Unable to reset Lamp Hour Meter on Panasonic PT-50LC14
Try this, using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
Posted on May 29, 2009
Anonymous
  • 81 Answers
SOURCE: resetting lamp hour meter on panasonic tv
press volume down on tv and pip or split on remote
Posted on Nov 19, 2009
Anonymous
  • 32 Answers
SOURCE: How do I reset the Panasonic PT-40LC12 projection
Usually you hold Vol - on the tv itself and press and hold down the pip or split buttom for 5 seconds until lamp reset is displayed on screen set to 0 and thats it
Posted on Jan 20, 2010
Testimonial: "Thank you so much for your help. Worked like a charm!"
How do I reset the Panasonic PT-40LC12 projection TV's lamp hour meter. What is the command?
Jan 20, 2010 | Panasonic PT-40LC12 40" Rear Projection...
I just replaced the lamp on my Panasonic PT-40LC12 TV. How do I reset the timer and make the red light go off?
what you need to do is have your remote handy and go up to the tv. Hold volume down the tv and pip on the remote for 5 seconds.
Dec 08, 2009 | Panasonic PT-40LC12 40 in. LCD Television
Panasonic pt 40lc12
THIS TV HAS ONLY ONE LAMP. HAVE YOU DOUBLE CHECKED THE LAMP ASSESS DOOR BECAUSE IF IT IS NOT SECURE, YOU MAY HAVE ISSUES
Jul 07, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Lamp on Panasonic PT-40LC12 will not reset.
you may want to try to do a hard reset, the way you do that is, you turn your tv on, and unplug it while it is on, after 15 seconds, plug back in, should turn itself back on, if not turn it on, and see if it is gone, if it isnt gone, you will have to look online for the code to get into the service menue, there will be another reset in there, that should definatly get rid of it.
Jan 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic hdtv
Pull the left front panel off of the unit and you will find the lamp door behind that panel. It is very simple to pull the lamp and most times you can even see the element in the lamp has blown. You can easily buy and install the lamp yourself.
Mar 19, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Lamp meter on Panasonic PT-40LC12 ?
Good Luck...
Mar 16, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Ballast problem on PT-40LC12
Sent me the serial number, and I can check for any re-call ...
my e-mail is <[email protected]>
Feb 01, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Resetting lamp panasonic PT40LC12
Jan 06, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
61 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
