Check for dry solder joints especially on the main power output transistor.
A blown power transistor will stop the 'Current Drive' from engaging so if the problem you have is intermittent then it is most likely dry solder joints.
Hope this helps.
SOURCE: what speakers can i used for technics su-v55a
Hi and welcome to the site,
The specifications prescribes:
Offhand, any 8 ohms speaker rated at 60 ~ 100 watts would be compatible.
Good luck and thank you for asking.
SOURCE: su-v55a technics amp cuts off when volume up to 2.
poor solder connections to the volume pot It needs to be resoldered
I got a problem for su-v55a technics one speaker is not playing
SOURCE: My Technics SU-V55A amplifier cuts out after a
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on; or it may turn on but produce no audio to the speakers.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
