shake the cartridge well and put it back & check, replace with another cartridge, check half test page if no print on paper check on image on cartridge drum( while printings approx half page open the door remove cartridge & paper check print on paper,on cartridge drum) check transfer roller & replace If no image any ware replace "Power supply PCA"..
Dots, Lines
and smudges on the printouts are due to deteriorating cartridges and
cleaning the green drum of the cartridge may help temporarily. Take out
the cartridge and gently clean the roller/ green drum with a dry, soft,
lint-free cloth wiping off the toner dots marks/ lines. Also, make sure that the visible inside of the printer is clean and ther is no spilled toner inside, which sometimes results in dots. Let me know if any further clarification/ assistance is required.
GoodLuck! Dont forget to appreciate the solution if I could have been of any help! CreativeTECH
Have youpulledthe tapefrom thenewcartridge? If you pulled, then push the green button on the printer, if a blank page again disassemble laser module and clean dirt with cloth and alcohol.
If you are getting correct test page without errors, simply unplug your printer's USB Connection from PC. uninstall Printer drivers and software. restart PC.. Re-Install New Copy of Drivers and Software.. THEN PLUG THE PRINTER USB CABLE TO PC.. try printing after proper driver is installed..
Depending on how tight or wrapped inside machine, You may try to open rear of machine and pull out the paper jam SLOWLY making sure you do not tear the paper where it can not be easy to get to.
