Take the carb off and you will see the little rubber mounting on the fuel tank.I mean the connection between the carburator and the fuel tank. Shake a little bit the whole saw. If there is gasoline coming out on the rubber mounting than it means that the fuel tank respirator filter is dirty and air cannot exit the fuel tank so it will get gas out at the rubber mounting because the pressure inside. To solve your problem for the moment try to push out this little filter. Take off the gas tank cap and look inside , you will see an alloy piece with a hole in the middle. Use a very thin screwdriver or something similar and push it through this hole , this way you will push out the filter on the other side. Do not use a drill bit. I did it, bad idea.
Have fun !
