Question about XO Vision XOD1735 Car DVD Player
Xo vision xod 1750 i have two ground wires and a praking light wire how do i hook these up
3 Related Answers
Anonymous
SOURCE: xo vision xod-1730 product showing no image?
to watch dvd video on xod1730 like what adamdog said you need to attach/mix the pink/braking wire to black/ground wire and if you want to disable the pink/braking wire all you have to do is not to attach it to black wire or any wire and cover pink end wire with electric tape.
Posted on Jun 13, 2008
Anonymous
SOURCE: xo vision xod1736 cant get it to work
Just hook up the Brake wire to the Black Wire. I have this same unit and this enables you to watch videos at all times. favicon.ico PR: wait... favicon.ico I: wait... favicon.ico L: wait... favicon.ico LD: wait... favicon.ico I: wait... wait... favicon.ico C: wait... favicon.ico SD: wait... close.gif close.gif
Posted on Jan 04, 2009
Anonymous
  • 3 Answers
SOURCE: help me with back up camera for xo vision xod1740bt
I am just giving a suggestion. I too need to know how to wire this. From what you posted it sounds like you hooked the wire to a constant +12v that is always on. Forgive me if I am wrong. Anyway, Did you connect this wire to rear reverse light power. I think from what you say it is supposed to be connected to the positive side of that light. If this solves your problem can you PLEASE let me know the full details of everything else you hooked up on the circuit to make the backup work. For instance what is the label of the orange wire. TIA.
Posted on Apr 06, 2009
How do I do the bypass on watching a dvd?
unhook the wire that goes to the parking brake with the unit off. Turn it on and when it asks for that wire to be plugged in, hook it to a ground or the ground wire
Mar 27, 2010 | XO Vision XOD1742BT Car DVD Player
Warning message!
this wire is the gray wire with the round eyelet. go to a metal ground and the Video will play
Jan 23, 2009 | XO Vision XO9013 Car DVD Player
XOVISION CAR DVD PLAYER SOUND NO PICTURE
hook your brake line wire from stero to your ground wire. it needs to be grounded
Dec 30, 2008 | XO Vision XOD1735 Car DVD Player
Xo vision xod1736 cant get it to work
Oct 30, 2008 | XO Vision GX1027D Car DVD Player
Xo vision XO1943BT
CHECK YOUR WIRES AT THE HARNESS WITH A TEST LIGHT TO BE SURE YOUR GETTING POWER TO THE HARNESS.AND A GROUND AS WELL. ANOTHER WAY TO CHECK IS TAKE THE UNIT OUT AND CONNECT DIRECT TO THE BATTERY UNDER THE HOOD
Aug 25, 2008 | XO Vision MD068 6.8 in. Car Monitor
XO Vision XO-141FM 14.1 in. Car Monitor
Check that you have good ground connections.
Use DVM to check if you have 12VDC to player.
If you have no DVM, you can use small car light bulb with leads.
If bulb lits from ground and hot wires, then player is bad. Or most likely a loose connections.
[email protected]
Feb 02, 2008 | Car Audio & Video
XO Vision XOD1740BT
ground the brake . all u need to do.
Dec 26, 2007 | XO Vision XO-1400 Car DVD Player
Xo vision xod-1730 product showing no image?
each time i power up i have to preset the radio stations.this is very annoying on my xo vision 1730.When the stations are preset they should remain so .Any suggestions
[email protected]
Sep 13, 2007 | Car Audio & Video
XO Vision XOD1735 Car DVD Player Logo
Top XO Vision Car Audio & Video Experts
ADMIN Canada
ADMIN Canada
ray gallant
Relax
Relax
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
