Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
How much cost to repair vertical color lines on sony bravia 46 tv
Posted by ttbmarine on
mjsazon
    Filmmaker:
    Uploaded 5 video answers.
  • 76 Answers
Please confirm if your model no. is KDL-46s2000 to assist you further on your problem.
Posted on Oct 05, 2011
COLORED VERTICAL LINE ON THE ENTIRE SCREEN AND NO PICTURE Sony Bravia KDL-46VL160 46 in. LCD HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 03, 2015 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Dec 02, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Nov 28, 2009 | Sony BRAVIA KDL-46V3000 Television
A fine green vertical line displayed on the Sony Bravia 46.
Thats a pixel data problem, there's no data being sent to that row of pixels so they don't change color. This is a pixel address registry (PAR) issue and the PAR circuits need to be serviced its usually due to open or shorted SMT components on the PAR circuits. PAR also sends data, voltage, and control to each pixel, the green line you see are pixels that have voltage but because there's no data sent too them their all green because there's no control. If the pixels have voltage but no data or control they show up as green red, blue, yellow, or whit line vertically down the LCD panel. The vertical-horizontal section of PAR are controlled by 16 to 32 bit micro-controllers which may need replacing. If its under warranty take it back if not have your local repair center fix the tv for you...
Nov 09, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Thin line vertical on tv
The LCD Panel needs to be replaced to fix this problem. The cost of doing it out of warranty would cost as much as buying a replacement set.
I hope this helps,
Skyassoc
Oct 31, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
My Sony KDL-32XBR4 has vertical lines for 5-15 minutes on startup
I have a 46 inch , Sony XBR 4 tv . The past week there has colored vertical lines that appear on the screen for about 10 minutes . Then they go away . What is the problem and solution?
Jul 10, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Vertical Lines of Sony Bravia 46
IT CAN BE FIXED BUT NOT BY YOU
BOARDS NEEDS TO BE REPLACED OR RIIBON CABLES NEED TO BE RESEATED. YOU CAN DEAL WITH A SERVICE COMPANY(NOT ALL ARE AS GOOD AND KNOWLEGABLE AS THE ONES YOUR READING HERE)
OR EXCHANGE IT
YOUR CALL
Feb 21, 2008 | Sony BRAVIA KDL-46V3000 Television
SONY 52" XBR5 Screen Damage
You are correct, the screen is damaged and in most cases cost mre than a replacement tv. There is no repairing a damaged LCD panel, just replacing.
Jan 31, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Vertical lines in screen
Are the Lines Symetrical in distance and space? Makes a diferernce..
Jan 21, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
451 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
