SOURCE: Can't Login: Multiple Users
If you have access to the computer through the teachers account, all you have to do is throw out the multiple users control panel, multiple users extension and the prefrences, once you restart the multiple users are deactivated.
SOURCE: Mac OS X 10.4 Installation problem
can you help me about my problem about intallation of mac os 9.. i have a G3 model of macintosh iwant to convert the mac os to windows. my question is is it posible to convert then mac os to windows? how? can you hel me.?
johannes
from philippines
SOURCE: Can't install Mac OS X Leopard on Power Mac G5.
email me at [email protected] i have the fix for you
SOURCE: when you power on the (apple) or (mac os x) iBook
Congratulations on your new computer! What you need to do is reinstall the operating system, after wiping the computer:
When you get to step 3, you should have a menu bar at the top. Select Utilities -> Disk Utility. Select the computer's hard drive, and 'Erase'. Call the new partition whatever you like, but make sure it uses Mac OS Journaled Extended file system. Follow the instructions and you'll have a machine like new!
If you don't already have an install disk, watch out - you can only install Mac OS up to Mac OS 10.5 on your iBook. Don't buy a 10.6 (Snow leopard) disk, as it won't install!
Hope that helped, good luck!
SOURCE: I was given a power
Apple has a guide on resetting the administrator password here: http://docs.info.apple.com/article.html?path=mac/10.4/en/mh655.html This one is for OS X 10.4 (Tiger) but the method is the same for newer versions. In older versions the only difference is that the reset password option mentioned in step 3 is located in the installer menu instead of the utilities menu.
