No real way to tell without opening it up I would guess that there is either a bad cable or a loose one. It's unusual that pushing by the touch pad effects the video, but I don't know what your working on either. You may have posted in the right category but it isn't showing me any of that since I'm answering you from my notifications
Thanks, Josh! I took the screen apart and the connections looked solid. How do I check the other end that is attached to the mother board Aand will it be a plug-in or welded connection. The laptop is an Acer Aspire 3500- so it's old- I am using this as a learning tool! I think my next step is to replace the screen even though the connections looked solid. I am assuming that the video card is not the problem- if it is- can it be changed or is it a part of the mother board?
Well I'm guessing it's the cable connection between the monitor and the the motherboard. The video is an integrated chip on the motherboard. To check it you will have to disassemble the whole laptop. If it turns out to be the video chip you can have them RE-FLOWED not sure on the cost as I have never looked into it. If the system was left on for extended amounts of time it's whole life then it has been under a lot of heat stress, this can be very ******* your video cable. The same goes for using them in the extreme cold if even just opening it up in a cold car. The wire would be cold and brittle and could be damaged under the stress. Enough of the maybe's, If you are just looking at learning and maybe getting it running then search e-bay see if you can find one cheap enough. After you get it opened up you will have a better idea maybe, or if you have a volt meter you could ohm it and check if all the wires are good.
Thanks Particalzman,
The comment about leaving it in a car in below-freezing temps may well be pertinent! I have decided this is beyond me and will donate the machine to Free Geek!
If you took the screen apart you can take the rest apart just check on the net (ebay) see if you can find a video cable for your model then if it is in your budget (or cheap enough to justify a best guess fix) then take it apart and make the connections, just make sure that you note the location of screws that are different if you encounter any. Also be sure to be delicate when prying the case, or connection fasteners. BTW Josh and Particalzman are the same person don't know why fixya labels it different sometimes.
