Question about Maytag Ensignia 3.3 cu. ft. Top Load Washer
I have a Maytag Ensignia MAV6457AWW washing machine that has a noise in the lower end of the agitator (which sounds like the transmission area) It is a rattling sound like something has broken. It is affecting the performance of the washer, where as it seems like that in the spin cycle the clothes are not fully wringed out. The noise is there in the wash & spin cycle. What are your thoughts on this? Thank you for your time..."
Posted by Ken Dunn on
  • Maytag Master
  • 17,130 Answers
In this case it seems that the main bearings on the shaft is a suspect. However if you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Oct 05, 2011
Maytag Dependable care, LAT9416AAE transmission shaft agitates but agitator does not
then the agitator cone inside the machine has a stripped spleen
not hard too do with castings
you need to demount the internal cone and check its spleen connection is solid
its much like the half shaft in a car
Feb 08, 2015 | Maytag Washing Machines
Washer wont agitate, pops breaker
Could be the gears/transmission for the agitate cycle are jammed, the motor then freezers, creates an overload and the breaker pops.
Jan 27, 2014 | Maytag Ensignia MAV4758AWW Top Load Washer
Maytag agitator will not turn
Sounds of a loose motor or need brushes replacement.
Jan 13, 2018 | Maytag MAV6457 Top Load Washer
Maytag washer mav4757aww was agitating a little then would stop and make a slight humming sound. Now it won't agitate at all , it just hums and starts to smell like something is getting hot. It will...
Unplug the unit and remove the front panel and look at the space between the motor and transmission find the coupler that connects the two together this could be broken. You may have to lay the unit on it's back to check this out. It's a cheap fix if its the coupler. Let me know.
Sep 27, 2011 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag top-loader making very load creaking noises from agitators
it could be you lelft something in the pocket of your pant that fell out an didnt drain out an si in the bottom of washer tub you have to remove the agitator an the basket if you dont know how call a techican ok are try an take a flashlight an see if you see any thing stuck in the bottom are the side of the basket ok
Oct 21, 2017 | Maytag Ensignia MAV4758AWW Top Load Washer
My Maytag Ensignia washer is not spinning well. It bangs side to side with even the smallest loads. It seems like something is loose. Is this something I can fix myself or do I need a repair mans help....
Try leveling the washer... If the washer is level, then don't wrap the clothes around the agitator...drop the clothes straight in, on top of each other evenly around the agitator. The Ensignia washer has a Dual action agitator... That means the clothes roll over them selves, instead of moving side to side, as with a traditional agitator. wrapping the clothes around the agitator will cause the load to be un balanced and then cause the "banging" noise... this should take care of the problem...
Jul 31, 2009 | Maytag Ensignia MAV4758AWW Top Load Washer
A screeching sound during agitation cycle only.
sounds like a bad clutch. check the transmission out for ware and inspect the clutch as well. make sure the brake is not dragging as well.
May 22, 2009 | Maytag Washing Machines
Spin cycle not working properly
On the transmission there are two shift arms. One shift arm controls the agitator and the other shifts to spin the cloths. If the washer has been making a "clicking" sound when it trys to spin, the solenoid that shifts the spin shift arm is not catching and the drum will not spin. The other possibility is the spin clutch is slipping and make a "grinding/ratcheting" sound. Neither, unfortunately are inexpensive to fix.
If you can describe the sound and when it occurs, I might be able to get closer.
Let me know.
Regards,
May 15, 2009 | Maytag Ensignia MAV4757AWW Top Load Washer
My wife wants the agitator removed so that we can clean it.
Pull off the top cup, then use a socket wrench to remove the bolt to separate the agitator.
Apr 11, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Ensignia Smoking
I had the same exact problem, called a repairman to take a look..he informed me the motor has burnt out! His first thought was the transmission, and said having the motor burnt out is better since it is less expensive.
Mar 21, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
Maytag Ensignia 3.3 cu. ft. Top Load Washer Logo
268 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
Michael Thomas
Michael Thomas
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
