E000 fixing overheating E001 fixing assembly overheating E002 fixing assembly low temperature E003 post-standby fixing low temperature E007 fixing film rotation error E010 main motor rotation error E014 fixing motor rotation error E019 waste toner case full, waste toner case full sensor error E020 toner clogging between sub hopper and developing assembly E024 developing assembly connector disconnection E025 hopper motor, bottle motor error E032 NE controller counter error E064 power supply voltage error (high-voltage) E100 BD interval error E110 scanner motor error E191 communication error for high voltage power supply E202 CIS home position detection error E225 CIS light intensity error E227 reader unit power supply error E248 backup memory error E261 zero-cross signal error E315 image data error E400 feeder communication error E490 wrong DF type E500 finisher communication error E503 finisher internal communication error E505 finisher backup memory error E514 stack delivery/trailing edge assist motor error E519 gear change motor error E520 off-set motor error E530 rear alignment error E531 stapling error E532 stapler shift error E535 swing error E537 front alignment error E540 stack tray ascent error/upper tray ascent error E542 lower tray ascent error E577 paddle error E584 shutter error E590 punching error E591 puncher dust sensor error E592 punch horizontal registration sensor error E593 punch shift error E5F0 saddle paper positioning error E5F1 saddle paper folding error E5F2 saddle guide error E5F3 saddle alignment error E5F4 saddle rear stapling error E5F5 saddle front stapling error E5F6 saddle butting error E5F8 saddle connector error E5F9 saddle switch error E602 hard disk error E604 image memory error/shortage E609 hard disk error E610 herd disk coding key fault E674 fax board communication error E710 IPC initialization error E711 IPC communication error E713 communication error for finisher E716 communication error for pedestal/ communication error for 3-way unitA1 E717 communication error for NE controller E719 coin vendor error E730 PDL software error E732 scanner communication error E733 printer communication error E740 Ether board error E743 DDI communication error E744 language file/boot ROM error E745 TokenRing board error E746 accessories board wrong model error E748 controller board and SDRAM size mismatch E805 fan error
Regarding most common errors related to fixing section:
E000 The temperature of the fixing assembly is abnormally high. 0001 While startup control is under way, the reading of the main thermistor is less than 30 deg C continuously for 200 msec or more 1 sec after the start of power supply. While startup control is under way, the reading of the main thermistor is less than 70 deg C continuously for 200 msec or more 2 sec after the start of power supply. While startup control is under way, the reading of the main thermistor is less than 120 deg C continuously for 200 msec 6 sec after the start of power supply. The startup control does not end 30 sec after the start of power supply. Reset the condition in service mode: COPIER>FUNCTION>CLEAR>ERR. Replace the main thermistor. Replace the DC controller PCB
E001 The temperature of the fixing assembly is abnormally high. 0000 The reading of the main thermistor is 250 deg C or more continuously for 200 msec. 0001 The hardware circuit detects overheating of the main or sub thermistor for 200 msec. 0001 The hardware circuit detects overheating of the main or sub thermistor for 200 msec.
E002 The rise in temperature of the fixing assembly is faulty. 0000 While startup control is under way, the reading of the main thermistor is less than 115 deg C continuously for 400 msec 1.3 sec after it has indicated 100 deg C. While startup control is under way, the reading of the main thermistor is less than 150 deg C continuously for 400 msec 1.3 sec after it has indicated 140 deg C. Reset the condition in service mode: COPIER>FUNCTION>CLEAR>ERR. Replace the main thermistor. Replace the DC controller PCB
E003 The fixing temperature is too low after a standby state. 0000 While regular temperature control is under way, the reading of the main thermistor is less than 140 deg C continuously for 400 msec or more. Reset the condition in service mode: COPIER>FUNCTION>CLEAR>ERR. Replace the main thermistor. Replace the DC controller PCB
E007 The rotation of the fixing film is faulty. 0000 While the fixing motor is rotating, the marker signal is not detected for 6 sec with the reading of the main thermistor indicating 100 deg C or more. Reset the condition in service mode: COPIER>FUNCTION>CLEAR>ERR. Replace the main thermistor. Replace the DC controller PCB REPLACE FIXING FILM ASSY(HEATER)
Canon 7050 E000 Heater (Reset by unplugging machine) E001 Heater triac, DC controller, AC driver (reset by unplugging) E005 Fuser cleaner belt at end. Replace. E010 Main motor, DC controller or DC driver board E011 Any motor ( main, scan, cleaner belt, duplex, toner, lens) DC driver, DC controller, duplex driver board. E020 Toner out signal has been sent for at least 3 minutes E050 Duplex E203 Scan motor, DC driver, DC controller E210 Lens home sensor not actuated or won't deactuate E240 Controller board E241 Controller board E242 Controller board E400 DC controller, Doc. Feeder board, 24V power supply E500 DC controller, sorter board, 24V power supply
'what sometimes happens is that the sensor flag/arm call it what you will, twists out of its holder and jams, hence the machine thinks that there is still paper. the flag/arm should pivot freely'
I have a xerox 3040 printer, but when I printing he report the problem (error)-024-958. I I know that the problem is in the size paper, but how is it possible to be right paper for printing. Please Help???
The DC error is most likely caused by a shorted or grounded speaker wire. Check all speaker wires, correct the problem, and then go into the sound setup settings and reset the POWER IC to ON.
