I have a samsung hpr4252x/xaa that has a buzzing sound coming through the speakers. When theh volume is on mute it sounds like dead air coming through the speakers. How can i fix this? I can hear the dead air when I change the channels as well.
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience http://electro-medical.blogspot.com/
had this problem. it turned out to be the color wheel. i left it alone but in 1 month's time, the color wheel shattered!. replace the color wheel asap...coz it's a messwhen it breaks
Start- Control panel- Sounds and Audio Devices- In the device volume section click Advanced- Click Advanced again and check if In the other controls section 1 PC Spk mute is checked if so uncheck it If that does not work please let me know so I can help you further
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
Reinstalled sound drivers?
Checked your speaker cord to make sure it comes into the green hole on the back?
made sure your speaker wires are not broken?
Volum on the speakers?
Control pannel> Sound> Speaker Icon: Are the controls HIGHLIGHTED? If not sound driver is not loaded.
Check Volum MUTE. SOme programs MUTE your volume without a warning.
