Question about John Deere Garden
Jd lawn mower deck belt routing 212 mower routing diagram for mower deck on212 jd mower
Posted by Patsyj Champ on
5 Related Answers
farmerbear
farmerbear
  • 490 Answers
SOURCE: need mower deck belt diagram for L-130 John Deere
I have found the manual at JD's website. Click the link and scroll down in the left column until you find the heading for replacing the belt. I contains big, clear photos. Here is the link:
http://manuals.deere.com/cceomview/OMGX21647_K3/Output/Index.html?tM=HO
You can copy it into your browser window or type it in. I sure hope this helps you out. If I can be of any further assistance, please let me know:)
Posted on Aug 21, 2010
Phil Rivera
  • 83 Answers
SOURCE: belt broken on riding lawn mower (john Deere LT
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
This link will send you to the illustrated parts list on the john deere site. It shows the belt routing in the part diagram. Hope this solves your headache.
Posted on Mar 30, 2009
Joe Hogan
  • 10865 Answers
SOURCE: Installing mower belt
The pulley at a wierd angle is the tension pulley. You may get the manual on line for free if you are lucky but not all mower manufacturers are that generous. What kind of mower do u have?
Posted on Mar 31, 2009
Anonymous
SOURCE: john deere 316 belt
I am so far from expert...me answering this surprises me. However, I can...JD Small Engines has plenty of diagrams for the 316. Here's how a old single lady changes the belt on her 85 316. There is a bolt running from side to side of a black metal box...on the very front at the bottom of the mower below the grill. If you pull that out, just the front of the mower deck separates from the mower..slip the belt in and around the rear central pulley. Put the pin back in with the belt now around the back pulley and outside the part where the pin goes back in. Get a pneumatic tire jack and jack up the right (your left as you face the front of the machine) front pulley..try to catch the pulley armature or bolt so you don't torque the pulley. This releases the tensioner...thread the belt on the right pulley and reach up under the grill and put the belt over the front engine pulley....now all that's left is to get the belt over the left pulley. At this point, I remember having to either lower the deck to the ground or raise it up all the way...to the ground, I think as it wasn't already in the correct position. Once you start fussing with the left pulley, you will see it is spring loaded and easy to force the belt over if the right pulley is still on the jack. Really important to get the belt inside all the belt guides and lowering the deck before you frustrate yourself with getting the belt over the last pulley. When all is done, release the jack and everything tightens right up.
Posted on Jun 10, 2009
Anonymous
  • 218 Answers
SOURCE: I NEED TO SEE A DIAGRAM ON A JOHN DEERE 214 LAWN
Hi..my name is Keith..and you can go to an online lawn mower parts site and put in your model of lawn mower and search for the mowing deck..and they will have a diagram of the mowing deck with the belt on it..and there are several sites online but i'll give you the one i use www.outdoordistributers.com ...i hope this has helped
Posted on Jul 12, 2009
Operators manual for 84 Dynamark 4218
Randall, diagram for deck belt routing, check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Mower Deck Belt Diagram DIY
http://www.ssbtractor.com/wwwboard/messages8
lawn tractor belt routing Google Search
Belt Routing Charts for Lawn Mower Decks Canada
Jul 25, 2016 | Garden
Craftsman lt10 lawn tractor. Need mower deck belt routing
If there is no diagram on the deck, you will need to order a service manual from Sears, or search the internet for that model number.
Jan 21, 2014 | Garden
Need a diagram of how to route the blade belt on my JD 68 riding mower
there should be a diagram on your lawn mower deck on the bottom side or on the left top side.
Jul 08, 2011 | Garden
I need a diagram of the drive belt and blade belts. How they run above the deck.
Ok.... I have to guess what mower you have. I am going to pass a deck belt link below. The first pitcures that will come up are for John Deere. At the top of the page you will see brands with links to the belt routing. Click on the brand name for your mower and then locate your deck.
John Deere http://opebycrigby.tripod.com/decks/jddeck.html
MTD http://opebycrigby.tripod.com/decks/mtddeck.html
Murray: http://opebycrigby.tripod.com/decks/murdeck.html
The MTD and JD links have most deck belt routing pictures that can equate to other brands.
Thanks for choosing FixYa,
Kelly
Jun 09, 2011 | Garden
I need a belt diagram for secondary belt on a john deere f525 with a 48 inch deck
Hi and welcome to FixYa, I am Kelly
By secondary belt I am assuming you need the deck belt routing. Here is a picture of the front deck belt routing: http://opebycrigby.tripod.com/decks/jd/jdf525.jpg
Kelly
May 04, 2011 | Garden
Need diagram to replace belt on manual trans john deere 265
See if this is even remotely close to your mower deck:
http://opebycrigby.tripod.com/decks/jd/jd48edgew.jpg
Also see if you can locate the mower deck model number i.e STX 38, STX 42 (Deck color Black or Yellow?) Should be a silver decal with black lettering. Also... there is supposed to be a belt routing diagram on the mower deck. (Another silver decal with the belt routing picture)
Kelly
Apr 13, 2011 | John Deere Garden
I need a belt diagram for a lt166 john deere mower 48''deck
From the JD site, you can get the drive and deck belt diagrams here:
***Don't forget to VOTE for the guys who take an interest in helping!
May 25, 2010 | John Deere Garden
Diagram on how to replace belt on deck 48
This is an older model, but the routing might be similar.
Apr 25, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
1,296 people viewed this question
Top John Deere Garden Experts
Dennis Key
Dennis Key
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
