SOURCE: Picture is distorted on my Sony Grand WEGA KDP-65WS550 65 in. Rear Projection HDTV Television
Can you paste snap of distorted picture of tv here to understand what kind of distortion is this.
Thank you.
SOURCE: Toshiba 50H82 rear projection TV adjustment
The ser needs to be converged in the factory service mode
SOURCE: 52 in RCA rear projection television
Not haveing the convergence option on this set is a clear indication you have the fl231 fuse problem. this is a simple repair and i see it all the time at the shop. I would suggest you read the "fl231 fuse problem in the tips and tricks section of this website. others have repaired this for less than 10 dollars and about an hour. if you have any trouble be sure to let me know
SOURCE: RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
