You would better go to nokia care or any local cellphone repairer to get it restored .....
but i can't. i need to fix it now. i need my contacts right now please help me :(
2163361363 is master code...
if it not works send me the imei correctly...
Iam also facing same problem. My IMEI is 352936/02/285655/2
PLEASE TYPE THE FOLLOWING KEYS *#7328748263373738#!THIS WILL REMOVE YOUR SECURITY CODE AND RESET IT TO DEFAULT THE NOKIA DEFAULT SECURITY CODE IS 12345
The security code you have put to your phone could be reset to default by following a single and simple step, all you have to do is type the following keys:
*#7328748263373738# on the main screen, this will reset the security code to default. The default code is 12345.
Try this one :IMEI3568503/02/0040Master Code7773047464Hope it helps thanks.
You can use the master code 2163361363
Just enter it to as your security code then change it with the default one or anything that you wanted to use and very easy for you to remember.
I hope this will help!
00000 or 12345 try this code 0000 or 1234
Hi your unlock code is Master Code 2163361363
Input the master Code...
your IMEI: 3568503020040
mastercode:
0234366234
Under the circumstances best solution is to go to nearest Nokia center and ask them to reset /load the software again
Input this master reset code: 2163361363
Default Security Code:12345
but the master code you gave didnt work, how is that?
Send me the right IMEI number. (15 digit)
simply try this link
http://www.mobilecodez.com/unlocking/nok...
I think Others gurus have solved your problem, if you have difficulty let me know!
Regards
Ajay
Type: *#7328748263373738# on the main screen, this will reset the security code to default. The default code is 12345. Great solution.
UNLOCKING PHONE
Hi you can use codes to unlock the mobile .to get the unlock codes visit this link:http://www.unlocking4free.com/
Here they ask the following details before rendering the unlock codes they are1. Mobile model2. Country from where you brought the mobile3. Provider to which the mobile is locked4. Imei number of the mobileFinally they will send you the unlock codes at free of cost.onceyou entered the code in your mobile as for the instruction given by them .your mobile get unlocked and it accepts any network sim to get the IMEI: UnlockPhone Via IMEI. Your phones IMEI is your unique number that is given to eachphone. For each IMEI there is a unique unlock code that once entered into your phone will enable you to use any compatible sim card. You can get theIMEI for your phone by entering*#06# into your keypad. You will only need 1 unlock code to enable you to use any sim card in your phone and enable it to be "network sim free".
you can also try going to this site:http://www.foneszone.co.uk/unlock_codes/ though this site may not guarantee a free service..
Pls, contact any Nokia retail outfit near you to unlock the phone...
you will have to contact the phone provider with your details and supply proof of your ID eg:passport or motor car licence or registration no if this is what you mean by breaking the security code unlock any phone any network instantly paypal verified or Instant unlock code $1.99 Unlock any phone instantly online use any network paypal verified Hope this helps you
Instant unlock code $1.79
http://www.freeunlocks.com/chooseyourpho...
http://www.peters1.dk/unlock/nokia/?spro...
unlock nokia
hope this helps
Default code is 12345 if changed then go to nokia care
You cannot specify what location and network you use, friend. Please give more details like about your location the network provider (example:globe and smart here in the philippines)...so that I will try to unlock your cp using remote unlocking. If nor work I will send to you an unlocking codeHave a great day!
I have a problem with this question. How and why would someone change your security code?? How would they do this? Why would they want to do this?
you can try doing this steps:
UNLOCKING PHONE
to get the unlock codes visit this linkhttp://www.unlocking4free.com/
1. Mobile model
you can also try going to this sitehttp://www.foneszone.co.uk/unlock_codes/
Hi, your unlock code is Master Code 2163361363
I am also facing the same problem.. My IMEI is 352936/02/285655/2... Plz someone helpme.
