LG 50PG6000 50 in. HD-Ready Plasma TV Logo
Anonymous Posted on Oct 04, 2011
I have an LG tv it is about 2 months old and there is a white line appeared on the screen about a quater of the way down the screen however when i go to my virgin menu it dissappears its only when a channel(all) are on ??????
  • Anonymous Oct 04, 2011
    Have you tried disconnecting all the cables and switching of the TV for sometime??
    Then reconnecting all the cables and switching ON.
    Also ask your cable operator to check the line???
matt martin
Level 3:
  • LG Master 1,259 Answers
  • Posted on Oct 18, 2011
matt martin
LG Master
Level 3:
Answers
1259
Questions
12
Helped
297423
Points
3635
You may have a defective plasma screen. As you describe there is a white line or spot on screen. In repairing some of these (another manufacturer) we were asked to replace the plasma screen. This problem is referred to as hazing. You may ask for warranty repair service. Thanks for asking and show all hands of support!
Anonymous
Level 3:
  • Master 517 Answers
  • Posted on Oct 05, 2011
Anonymous
Master
Level 3:
Answers
517
Questions
0
Helped
117240
Points
1424
Good day!!!
please try to play a dvd to determine if the problem is on the TV itself or on the cable/aerial reception..
if the dvd plays and the TV looks fine so your problem is on the reception or cable connections please contact you cable provider if you are using cable or digital connections..
If you are using aerial please try to find the best position of your antenna..
However,if the dvd plays but the problem still persist..your problem is on the buffer board..
please go to this link:
http://www.plasmafix.com/plasma.php
Please don't forget to rate my answer if it is helpful..
Thanks for using fixya..
Level 3:
Top Expert:
  • LG Master 76,851 Answers
  • Posted on Oct 04, 2011
LG Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15004934
Points
237762
Hello
The T Con board of your LG that generates high voltage to plasma screen is fauty. It is somewhat costly board, and can be repalce as card basis. As the set is new, and warranty will be there with it, just contact the authorised service center and get it repalced by them. They have the liability to do that. If you want to repair it by yourself, tou have to spend an amount from your pocket. OK.
2answers
LG LCD TV not working with white vertical lines on screen?
The T con board is not working correctly with your TV or the cable connections are either broken or loose or the external device are not attached fully to the TV. Or the wiring is not been connected properly.
42inch LG plasma TV
well if you could please give out the model nuumber thank you
LG55LE5400 white lines, bad tuner board?
hi it sounds like you may have a panel fault, might best to get in contact with the people you purchased it from see if they can help good luck
regards
shaun
5helpful
Lines down screen
We have a Samsung LE32A457, whilst we were watching T.V tonight the top halve of the screen suddenly appeared with green lines halfway down the screen and that half of the picture was unwatchable, T.V is 2 years old. We have removed all scart leads but this did not help and the problem still exists, when shutting down a white horizontal line across the centre of the screen appears from this line upwards the picture is faulty. Any help or advice would be grateful.
Thin white horizontal lines have appeared on the upper quater of the screen. Under these lines a greena red line has appeared. Bottom three quarters of screen is good.
u have to change a capacitor(470mfd or 100 mfd) in vertical section of u'r tv circuit board..if u r a tech person try this...
Plasma only showing half picture
This is beyond consumer ability to repair. Please have it looked at by a qualified electronics service company.
I have a LG Plasma Flat screen TV. I purchased it
With seeing the picture it will be hard fro me to tell what..I am going to guess according to the information you've provided.
It could a buffer or a signal board(s). This TV is only 4 Months old I would call LG and file a warranty claim. LG (800) 243-0000
Best of luck
N Sabre
Black stripe down TV plasma screen
if your TV is still under warranty, call Samsung to get it fix. I seen this problem and is quite expensive to repair
36helpful
6answers
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
42 LG Plasma
It can be fixed but about $300 in parts.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
