SOURCE: Canon Power Shot A80 LCD screen not working.
http://www.fixya.com/support/r1237608-canon_powershot_cameras_pink_black
It seems that this is a problem with some of the canon pwershot series.
Please check out the link above regarding the same. It might help before you decide on repairs.
Please rate this solutions and thanks for using FixYa!
SOURCE: LCD screen don't work all the time
pls see the link
Flex Cable might be damaged u will get all
instructions and answer on this page u can do it urself it is a
frequent fault in screens that have twist function \
Pls rate me WELL !
See this link for Repair Instructions
SOURCE: Power shot A610 Self timer operation
Please see the manual on page 35.
There is the link of the manual
http://gdlp01.c-wss.com/gds/0900011224/PSA620610CUGad-EN.pdf
SOURCE: I have a power shot S2 IS digital camera. I have
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
For your particular model camera, pay attention to the UPDATE intro to the article.
SOURCE: How to download pictures from canon power shot
If your camera is not relatively new and you're running Vista or Windows 7, your computer may have problems seeing it. Unfortunately, this can't be corrected because Canon did not yet update drivers for your camera. But there exists a good, if not better alternative way to download your photos. Please don't take the following as a sales pitch as it's not, but please see this blog article, as it describes the use of an inexpensive USB card reader as a much easier, faster, and less error prone way to download your photos. In fact there are several important reasons discussed in the article for using a card reader vice downloading from the camera. USB Card readers are also very inexpensive these day, with cost virtually not an issue:
Testimonial: "That sounds like a good solution --- but I did manage to download thru my printer. Thanks"
