SOURCE: can i connect one two 667mhz rams in INTEL D102GGC2 mother board?
Memory
Two 240-pin DDR2 SDRAM Dual Inline Memory Module (DIMM) sockets
Support for DDR2 533MHz and DDR2 400MHz DIMMs
Support for up to 2GB of system memory
hope helpfull
SOURCE: I have a mercury pnmcp73vt motherboard.There is a
replace the stick of ram it sounds like its defective.
SOURCE: DDR2 Ram allergic problem....
When using different kinds of RAM together in the same computer, there is a general rule that the Slowest Ram has to occupy the first slots (the ones closest to the CPU and usually numbered on the Motherboard)
This is possibly the cause of your ram error although they're both 400Mhz, just try re-arranging them.
I think the Ram Error Code is two long beeps and the video error is one long beep and three short beeps.
Also, watch the Ram counter when you first turn the computer on, or check the "My Computer" properties to see that all the RAM installed is recognized.
SOURCE: I have an asus p5vdc-mx
What os are your using? XP, Vista, Win 7?) Also, was this a new motherboard and what type of case are you using? Lastly, I would recommend you checking your BIOS and make sure there are no limits set on the memory cap. (Usually found in older system but check anyway.)
Good Luck.
C2Solutions
