Kenwood VR-5700 Receiver Logo
Anonymous Posted on Oct 04, 2011
Kenwood Sovereign VR5700 Receiver mutes without prompting. I've tried: 1) shutting off and on 2) testing other inputs and headphones. Non work 3) testing different speakers. Non work It's a well ventilated area which doesn't appear to be overheating. This problem began happening sporadically about 8 months ago and switching the receiver off and on would resolve but now the mute button blinks 4 times when first turned on and never produces sound. Has this 10 year old receiver seen it's last days. Is it repairable or should I get the latest receiver that will last another decade? If the latter, any suggestions?
  • Anonymous Oct 04, 2011
    Seems I was able to resolve this one myself. Although the manual doesn't provide reset instructions, I was able to reset and resolve this issue by:
    1) unplugging the power cord
    2) press and hold the power button while plugging in the power cord. So, yes, simultaneously
    3) release hand from plugged in power cord while holding power button a few second
    4) Turn on
    It worked for me. I hope it works for you!
  • Anonymous Oct 08, 2011
    David, thanks for your comment. I did both read the manual and try the mute button. Clearly that wasn't obvious. My reset solution (which is NOT in the manual) only worked for 3 days. In fact, I started experiencing video issues with one of the inputs and when I reset it, I got the video back but lost the sound again. So, I'm back to square one. I learned that the 4 mute blinks when it first turns on is expected for this unit but the sound should kick in after a few seconds. To reiterate, the real challenge is that the sound sporadically exists and the video is starting to do the same. Any suggestions on a resolution? If not can anyone suggest a new but comparable receiver that I can use with other Kenwood Sovereign products? I would appreciate the help!
Anonymous
Level 3:
  • Master 8,546 Answers
  • Posted on Oct 06, 2011
Anonymous
Master
Level 3:
Answers
8546
Questions
Helped
2775441
Points
24828
I don't see you trying the MUTE button. Page 71. Second bullet. Blinking MUTE is actually mentioned.
http://www.retrevo.com/support/Kenwood-VR-5700-Receivers-manual/id/480ag222/t/2/
It's always a good idea to read the manual.
    More triage to establish failure boundaries is in order. Concentrating on just the audio: we need to prove the audio is still flowing inside the receiver before deciding to tackle amplifier self-protection as a cause.
    Read pages 69-70.
    What source(s) fail? All, one, test tones?
    Next time it goes silent observe if there was a click of the relay that you normally hear when it comes up correctly. That would indicate it is in distress and tryng to protect itself. Carefully disconnect each speaker AT THE BACK OF THE RECEIVER and see if it comes back up without needing to be reset. DON'T SHORT THE CONDUCTORS while either one is still attached to the receiver.
    If it still fails to drive the speakers, select the speaker test menu and see how that goes. Since it's an internally-generated tone it bypasses most of the logic and circuitry the 'normal' sources would pass through. If the tone works you have a preamplifer/processor level sound loss.
    Prove a source is flowing internally (FM) by running a set of RCA cables from any pre-out or Tape Out to any device you have that accepts Line Level RCA input and has its own speakers (TV???). If the sound is NOT there it's getting lost higher up the chain instead of out at the amplifiers.
  • Anonymous Feb 28, 2021
    i have the same issue with the same receiver and the speaker test menu doesnt provide any tones. what should i test next?
I can't get any sound from my Kenwood vr 60rs can you help me?
Certainly! If you're not getting any sound from your Kenwood VR 60RS receiver, here are some troubleshooting steps you can try:
  1. Check the connections: Ensure that all audio cables, including speaker wires, are securely connected to the appropriate outputs and inputs on the receiver and speakers. Make sure there are no loose connections or frayed wires.
  2. Verify the input source: Confirm that you have selected the correct input source on the receiver. Use the input selector buttons or the remote control to cycle through the available sources and make sure you have chosen the desired audio input.
  3. Volume and mute settings: Check the volume level on the receiver and make sure it is set to an audible level. Also, verify that the receiver is not muted. Look for a mute button on the front panel or the remote control and press it to unmute the audio.
  4. Speaker settings: Ensure that the speaker configuration settings on the receiver are properly configured. Verify that the speakers are set to the correct size, distance, and channel assignment. Consult the receiver's user manual for guidance on adjusting these settings.
  5. Test different speakers: If possible, try connecting different speakers to the receiver to rule out any issues with the speakers themselves. This will help determine if the problem lies with the receiver or the speakers.
  6. Factory reset: If none of the above steps work, you can try performing a factory reset on the receiver. Refer to the user manual for instructions on how to reset the receiver to its default settings. Note that this will erase any custom settings and preferences you have saved.
2answers
Kenwood KRV-6050. Is there a way to change headphone jack on it from output to an input so I can play my cellphone playlists over home speakers?
You can’t through the head phone jack but you can behind the receiver. In fact there are several ways you can play music from your phone to the stereo. Use the input for CD player, Tape 1 or 2, video player. Usually the Auxiliary would be used but you don’t have one. Almost all inputs will work except phono.
How do I connect a Kenwood KR 5560 amplifier to my TV for stereo sound?
Your tv should have rcas out (white and red). Out of them to any input on amp.
Getting no audio from speakers on a Vizio E421VA LCD HDTV, any ideas?
Do headphones work?
my guess is either the headphone socket or associated wiring/soldering is faulty or there is a faulty connector within (connector associated with the audio)
2helpful
Pioneer VSX-456 headphone jack problem
No the headphone jack doesn't disable the speakers. There are two switches in the lower middle of the receiver that are labeled speaker A and B. Pushing one of these should disconnect the speakers from the receiver.
Kenwood KRF-V6070D no audio
• If you have a multimeter, check for DC outputs on the amps,
coming from IC301/401 (hybrid IC)
• Or use a headphones .It could just be some cold solder joints
( if there is no humming in headphones) or regulators
on the power supply.
• Check other inputs, you might find one working.
Let me know if you need further assistance!
Onn Wireless Mouse has stopped working. What do I do?
Mine would work fine until I turned on my wireless headphones...then the mouse would move a little stop.....move a little....then stop.
I made sure my headphones were on.
I turned off the mouse, moved the mouse reciver to a USB port on the front of my computer (the mouse reciver and the headphone receivers were next to each other on the back of the computer). I turned the mouse back on.
The computer imediately gave me the "installing USB driver" notification.
When it was complete....both played nicely together...no more problems.
I inherited a technics SL-6 turntable system and a very old sears audio by fisher am/fm stereo receiver along with 1 pair of kenwood ks-401ht front speakers and cant get any sound. I have the technics...
Your connections seem to be right.
Let's distill this down to its simplest configuration... does the onboard FM produce sound? If not, nothing will.
NEVER USE MAXIMUM VOLUME FOR TROUBLESHOOTING.
Turn the volume control to something medium.
The errant switch, control or condition may change and you will suddenly release the amp's full power and possibly destroying your speakers. If a signal isn't audible at 1/2 volume it's probably not there.
Carefully examine the front panel for clues like a misplaced Mute or Tape Monitor control or Multichannel Analog Input selected.
There is a good chance that a common control may have developed a high-resistance or 'dead' spot through idleness and is causing your symptom. Turn the POWER OFF and operate every control throughout its range a number of times, especially rarely-used ones like Tape Monitors and the Mute control.
Turn the volume to something reasonable and see if that helped.
Remote code
1. programed RCVR with code 0314
2. then assigned a key (such as the TV/VCR key) with the EFC number of 300
3. then reprogramed RCVR w/ code 0027
498 "surround mode"
568 "+10"
578 "band"
370 "stereo"
702 "6"
444 "4"
447 "2"
317 "8"
701 "0" (zero)
450 "7"
704 "5"
707 "3"
449 "1"
577 "9"
384 "tape 2"
252 "mute"
255 "vol down"
512 "power"
515 "vol up"
572 "channel down"
257 "channel up"
Try This an see if works
No sound
1-connection with the input devices or connection of speakers cables is faulty.
2-the input source do not match with receiver.
3-master volume is turned too low.
4-mute mode is set.
5-headphone are connected.
6-selection of input source is wrong.
7- no digital signal in input.
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Ngoro
john h
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
