Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
..coleman electric fireplace Model #FL28R start
Posted by Norman Arias on
Mike Cairns
  • 3,053 Answers
Hello, norman
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved by the other fantastic great experts. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about electric fireplaces and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/home-improvement/heating-and-cooling/fireplace.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
Posted on Oct 31, 2011
Purchased a great world model swe071 electric fireplace. How do you control the feature to make the flame colors change automatically without using the remote every few minutes. Lost manual
I bought a great world ltd swe067b electric fireplace ... - Fixya
www.fixya.com/.../t25420081-bought_great_world_ltd_swe067b_electri...
Feb 12, 2015 - i bought a great world ltd swe067b electric fireplace a couple of months ago.it wont ... Purchased a great world model swe071 electric fireplace. Howdo you control the feature to make the flame colors change automatically ..
Oct 25, 2015 | World Heating & Cooling
Where can I find parts for coleman electric fireplace model#FL-28R?
try searching through google.com that's how I find things .
Mar 04, 2015 | Coleman Heating & Cooling
My problem is I have a electric fireplace the insert is a colemen and the heater stoped I bought it a Costco about 4 years ago
It may need repairing, do not take risks trying to fix it without an expert. But its 4 years old so its better to replace it with new.
Dec 15, 2013 | Leisure HOMEPRIDE Electric Fireplace...
Classic Flame 39EB500GRS Error Message E3?
I had same problem. Just stopped worked and blinked E3. I used the troubleshooting wizard on ClassicFlame's website. Shut power off (it's hardwired to 220v) for a couple minutes and it started back up. Never did find out what caused the error.
Dec 10, 2013 | Classic Flame 39EB500GRS 39 inch Builders...
Electric fireplace
Is it that soud stay for long time, let say 10 minutes?
It can be some piece of metal moving when fireplace heats up.
If this fireplace has fan installed, small lousy bit of metal can play.
Nov 13, 2013 | Heating & Cooling
GAS FIREPLACE SOMETIMES TURNS ON AND SOMETIMES NOT. ALSO, IT CAN BE ON AND THEN THE FLAME GOES OUT BUT A FEW MINUTES LATER COMES ON. SUGGESTIONS?
This is a typical situation for a warn Powerpile generator. Your fireplace works by this generator generating heat from your pilot flame and converting it to less than 3/4 of a volt or 750mv. Your gas valve will eat up half of this electricity when running. So when you Powerpile gets warn it might only generate 400mv and when the gas valve turns on will bring it down below 200mv. This will start to drop once the main burner turns on and once below 150mv is no longer able to power the gas valve resulting in the main flame to go out. Minutes later the generator will build its power up again and repeat the cycle. The generator looks a little thicker than a crayon and has a red and white wire coming off it. They are easy to change but the tight spaces on a fireplace can make it very difficult.
Nov 02, 2013 | Heating & Cooling
Our dimplex electric fireplace model number 28106D3F shut off and won't turn back on
Turn the Master ON/OFF Switch to OFF. Unplug the fireplace from the wall receptacle and leave unplugged for 10 - 15 minutes. This will give it time t reset itself. In the future, if you finding you're have to do this more often. Unplug the fireplace, stop using it and call Dimplex USA Technical Service 888-346-7539 for further instructions.
Mar 09, 2011 | Heating & Cooling
Our coleman fireplace insert starts to warm and then shorts out
Not sure if you have an electric fireplace or a gas fireplace. But, from the way you worded the description of your problem, I'm going to assume that it's electric. I'm also assuming that all the other features of the fireplace work, but the heater doesn' t. If that is the case, below is what the Owners Manual recommends doing.
5. Flame effect operates, but heater does not blow warm air
The TEMPERATURE button is a thermostat control for the heater. Each preset temperature setting has a different thermostat setting as shown to the right:
The heater will NOT activate if the room temperature is above the thermostat setting. If the ambient room temperature is 78° F the user will need to select Setting 3 in order for the heater to be activated. It is normal in warmer climates and in rooms with higher ambient temperatures for the heater to not activate on the lower settings due to the thermostat control. 5a. Try increasing the temperature setting. See drawing:
temp-control-fig.jpg 6. If unit heater does not function, but Power and Heater switches are in the "ON" position and thermostat is set on "HI" 6a. Turn all switches to the "OFF" position and unplug the unit from the wall outlet for 5 minutes. After 5 minutes plug the unit back into the wall outlet, and operate as normal.
Mar 01, 2011 | Coleman Heating & Cooling
My heater on my coleman electric fireplace Model #FL28R the fan works but not the heater . . please help!
HI,
Sorry for my english, I,m french. I'm from Québec, Canada.
I have the same problem with my fireplace. Same model.
Do you have the manual or the papers who came with the fireplace. My electrician need it. May you scan or fax to me?
Thank you very much.
Jacques Blanchet
Fax: 1-819-762-0130
email: [email protected]
Dec 05, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Heating & Cooling Logo
548 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Bill Johnson
Colin Stickland
Colin Stickland
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
