Question about Olympus m:robe MR-500i MP3 Player
Olympus m:robe MR-500i My battery says charged but only works on AC. Otherwise the blue light flickers, but then goes out. When you unplug it from the charger it's dead. Information is still intact when plugged into AC again. Do I need a new battery even though it shows fully charged??
2 Related Answers
Anonymous
  • 69 Answers
SOURCE: my Olympus m:robe MR-500i MP3... Problem:
try:
click Start>Run then copy and paste the following:
C:\Documents and Settings\Username\Application Data\
replace 'Username" with the name of your user account and press enter
In the new window, find olympus and make sure there are no important data in it and delete the folder
then do the same in
C:\Documents and Settings\Username\Local Settings\Application Data
You will need to re-syn your m:robe and re add songs.
Or you can try sync on a different computer and resync on your own computer
Posted on Oct 07, 2008
Randy Morton
  • 479 Answers
SOURCE: Can the Olympus Mr:500i be made to play videos?
mrobe.org
Posted on Feb 18, 2009
My m:robe freezes at startup
Sounds like a software issue.try rebooting it,or re-formatting it to factory settings.hope this helps.
May 07, 2010 | Olympus m:robe MR-500i MP3 Player
My Olympus m:robe MR-500i MP3... Problem:
try:
then do the same in
Aug 12, 2008 | Olympus m:robe MR-500i MP3 Player
Blank Screen
Try pluggin in the USB cable and plug it in. if this works, re sync with m:trip
Its probably a problem with the HDD (hard Drive)
Apr 22, 2008 | Olympus m:robe MR-500i MP3 Player
Where can i?
hey.
go to the omlypus website and you will find a link to the software download on the mp3 players page.
this should help you.
Feb 14, 2008 | Olympus m:robe MR-500i MP3 Player
???caution please connect AC??????
From what I've learned from the manuel, and such, is that the dock is the only way to charge it, and M:trip software is the only software that is equiped to be used with an m:robe...so I would say that you should try to get a new dock, and software. If you can't find any try going to olympus them selves and maybe you can download the software directly from them
Jan 29, 2008 | Olympus m:robe MR-500i MP3 Player
M:robe 500i doesnt respond!
The basis for the camera is it is touch screen and if your friend sat on it .....you could say that that was one big touch (butt touch). What that probably did was over touch the touch sensor which screwed up the whole camera. The only thing I can say to you is you definitely have to send it in to a specialist........GOOD LUCK!!!!
Aug 31, 2007 | Olympus m:robe MR-500i MP3 Player
My m:robe wont work at all!
If the screen doesnt even light up then you pretty much stuffed.
If battery isnt charging then the battery's life is gone. you cant really get another battery all you can do is remove it to prevent damage and use it plugged in.
Open the case by unscrewing the four screws (2on bottom and 2 on side)
move the HDD (hard disk) and take out battery and unplug
replace HDD and lid.
Jan 03, 2007 | Olympus m:robe MR-500i MP3 Player
Doesnt work... at all
The battery on these units dies after so many recharges. You most likely need to replace the battery. It's not difficult and you can usually find replacement batteries on E-Bay for around $20.
Sep 27, 2006 | Olympus m:robe MR-500i MP3 Player
Olympus m:robe MR-500i MP3 Player Logo
Top Olympus Audio Players & Recorders Experts
Richard Schabler
KBeaN1
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
